rear doors rattling - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
rear doors rattling
Old 08-16-2014, 10:25 PM
rsplash40 rsplash40 is offline
rsplash40 is starting off with a positive reputation.
rear doors rattling
All,
I've had the rear barn doors and window start rattling lately no matter how tight I think I've closed them. The seals look ok, any one run into this before?
thanks
Mike
Old 08-16-2014, 10:44 PM
BigBlkEX's Avatar
BigBlkEX BigBlkEX is offline
BigBlkEX is gaining momentum as a positive member of FTE.
Yes look into the door seal mod. And the bumper stops that needed to be added to the glass door if your are missing them. There are different threads on here to do both
Old 08-16-2014, 11:40 PM
Restlesswildman Restlesswildman is offline
Restlesswildman has a great reputation on FTE.Restlesswildman has a great reputation on FTE.Restlesswildman has a great reputation on FTE.Restlesswildman has a great reputation on FTE.Restlesswildman has a great reputation on FTE.Restlesswildman has a great reputation on FTE.
I have the same issue. The wife was bothered by it so she climbed around the truck and located the rattle. Turned out to be the tail pipe over the axle.
Old 08-16-2014, 11:55 PM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
Quote:
Originally Posted by rsplash40 View Post
All,
thanks
Mike
Try leaving them open a bit to make sure that is truly it.
Old 08-17-2014, 12:02 AM
BigBlkEX's Avatar
Quote:
Hahaha I could only imagine how that would look going down the road with all 3 doors open!! :-) :-) :-) and have his wife drive the truck and him holding on the back listening for a rattle!!! Hahaha.
Old 08-17-2014, 12:51 AM
Quote:
I didn't say wide open.
Old 08-17-2014, 09:25 AM
hav24wheel's Avatar
hav24wheel hav24wheel is offline
hav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputation
The door seal mod fixed the rattle on mine. I even did the big seal around the rear opening without taking it off. That one is a huge pain and you need a helper along with more lube than you would think.
Old 08-17-2014, 11:24 AM
Quote:
Was there any way you could modify the latch to make them close a bit tighter?
Old 08-17-2014, 02:54 PM
jayjjcc's Avatar
jayjjcc jayjjcc is offline
jayjjcc is a splendid one to beholdjayjjcc is a splendid one to beholdjayjjcc is a splendid one to beholdjayjjcc is a splendid one to beholdjayjjcc is a splendid one to beholdjayjjcc is a splendid one to beholdjayjjcc is a splendid one to behold
fwiw I did the door seal mod on the 3 little pieces of door and changed the entire big seal for a brand new OEM one and I still have the noise I thought was the doors...
Old 08-17-2014, 03:44 PM
johntpr johntpr is offline
johntpr is gaining momentum as a positive member of FTE.johntpr is gaining momentum as a positive member of FTE.
Old 08-17-2014, 05:31 PM
Tylus's Avatar
Tylus Tylus is offline
Nuclear Machinist Mate
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
Try the door seal mod. It's $5-10 per door and makes a world of difference. Even if that isn't the ultimate noise, you'll have a better sealed and quieter X.
You'll need about 12ft of 3/8 of LATEX tubing for each door. Make sure to get latex as rubber and nylon will get overly hard in cold weather. I've bought some from Lowes, and eBay. Deals are out there if you look
I keep meaning to do my rear hatch. It's the only 1 left and you can tell it needs it compared to the other 4
As far as adjusting the striker plate, yes you can move it in to make the door tighter. Only positive of it IMO is the cost. You run the risk of the doors contacting body parts and it's only a bandaide
Brake caliper rattle at slide pins 6_Myles Excursion - King of SUVs 2 03-25-2016 02:57 PM
Door rattle supercrewser1751 2009 - 2014 F150 21 03-23-2016 07:46 PM
Supercab rear door Rattle F150MUTT 2015+ F150 2 03-18-2016 11:19 AM
1975 F350 with rattling doors JH1975 1973 - 1979 F-100 & Larger F-Series Trucks 12 07-27-2015 04:59 PM
2004 F150 Rear Door Panel Removal Willy2000 2004 - 2008 F150 1 09-19-2006 06:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
