Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
Old 08-16-2014, 10:16 PM
curtisbutlerjr curtisbutlerjr is offline
curtisbutlerjr is starting off with a positive reputation.
aluminium or magnesium motor brackets? what can i do with them
fixing up 1991 f150 with 4.9 6 cyl the brackets on motor for all the accessories are made of aluminium or magnesium is there any coating or paint i can use to make them look better on newly painted motor. i would like to clean metal in some manner or paint them silver but what can i use on such a metal? any suggestions
Old 08-16-2014, 11:46 PM
krooser's Avatar
krooser krooser is offline
krooser is gaining momentum as a positive member of FTE.
Use any paint you choose on the aluminum… they aren't magnesium.
__________________
Living the dream behind the Cheddar Curtain
'88 F-350 Crew Cab, 460 Fuel Squeezer
'97 Ram 1500, '99 Jeep Grand Cherokee. '90 Buick Park Ave. '52 Pontiac Catalina.
Plus a couple old dirt race cars.
Old 08-17-2014, 02:23 AM
Vadis's Avatar
Vadis Vadis is offline
Vadis is starting off with a positive reputation.
As Krooser said, the brackets are aluminum. You can use a degreaser to help break down any grim on them and then wash them down with water and dry them.
You can then hit the whole thing with a small wire brush on a drill, like this one:
Then wash and dry again.
After that you can spray a coat or two (or until fully covered) with some aluminum colored paint. You could also clear coat if you so wish.
This is mine before:
And after:
__________________
1989 F-250 Custom, RCLB, 300 I6/ZF5, 4x4, '92+ front clip, Dana 60 SAS, 4.10 LS, 285/75r16 Goodyear Wrangler Duratrac Build (In Progress)
1979 F-150, RCLB, 302, 2" body lift, 33" Widetrack Baja AT
1975 F-150, RCLB, 351M/400
Old 08-17-2014, 02:27 AM
BigSix1 BigSix1 is offline
BigSix1 is gaining momentum as a positive member of FTE.BigSix1 is gaining momentum as a positive member of FTE.
I used an aluminum-colored rattle-can paint (forget the brand, but it was probably Rustoleum, which I usually use) on the "alternator/air pump tree," and it came out well.
__________________
1972 F-100, 240-I6, 2x4, ("restified")
1981 F-100, 300-I6, 4 spd manual with O.D., 2x4 (currently functioning as a shed)
1988 F-150 300-I6, 5 spd. Mazda, 2x4 (R. I. P.)
1997 F-250 H.D.S.C., 460, 5 spd. ZF, 4x4 ( BIG Mistake...)
Old 08-17-2014, 09:31 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is online now
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Eastwood has some VERY GOOD engine detail paints
Here is one such example I always keep on hand
Underhood Detailing Kit
1st had experience
__________________
Looking for Blue 40-20-40 seats. PM me !!!
Old 08-17-2014, 09:43 AM
Eddiec1564 Eddiec1564 is offline
Eddiec1564 has a good reputation on FTE.Eddiec1564 has a good reputation on FTE.Eddiec1564 has a good reputation on FTE.
I used air conditioning coil cleaner to clean off my aluminum parts. Soak it really good and you see it start to foam up. Rinse off and dry, repeat if necessary then used clear coat paint(high temp) to keep them from "frosting" up with that white oxide aluminum does. Looks good years later.
__________________
95 E350 460/E4od 4.10 The Bus
89 F250 2x4 300/AOD 3.55
84 F250 4x4 300/np435 3.55 The BLUE MULE
85 Plymouth Caravelle
73 Buick LeSabre
Similar Threads
Totally Rad lukeg Super Duty & Heavy Duty 0 06-28-2012 11:33 PM
Tough coating? 97squarebody Paint & Bodywork 4 04-09-2008 07:42 PM
Refinishing Aluminium rims RobertNooy Brakes, Steering, Suspension, Tires, & Wheels 16 04-03-2008 12:10 AM
Widest aluminium rims icyford Super Duty & Heavy Duty 8 04-15-2004 09:48 PM
Aluminum Roof Coating for floors or bed MAHinton Paint & Bodywork 0 10-11-2003 02:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
vbulletin Admin Backup
