engine has come down with a miss! - Ford Truck Enthusiasts Forums
Old 08-16-2014, 09:49 PM
trinibob's Avatar
trinibob trinibob is offline
trinibob is starting off with a positive reputation.
Well have my first problem that I cannot fix!
Back ground
2003 F-350 4x4 4 door got it used with 123000 installed bank's headers, y pipe, k&N cold air intake, five star tuner with 87 octane tune tow & economy tune. Now has 144000 miles and during a camping trip started throwing a lean in bank 1 code two weeks later through the same code as well as bank 2 lean then started missing at cold start up which seems to totally go away after the engine is warm .
So figured it was time for a spark plug change had all the spark plugs and the rubber protectors and springs change as well as the coil packs inspected for cracks none were found also replaced fuel filter so I assumed the problem was fixed Well it came back again today.
just looking for direction as to what to start looking At next.
Thanks.
Old 08-16-2014, 10:00 PM
Modularation Modularation is offline
Modularation is starting off with a positive reputation.
Look for a vacuum leak.
Old 08-16-2014, 10:12 PM
trinibob's Avatar
Thanks I'm on it
Old 08-16-2014, 10:53 PM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
Check fuel pressure.
Old 08-17-2014, 12:08 AM
Army RET's Avatar
Army RET Army RET is offline
Army RET has a good reputation on FTE.Army RET has a good reputation on FTE.Army RET has a good reputation on FTE.
Just in case the odds are against you ... last winter my 02 V10 developed a miss. My indy shop replaced the plugs and one cracked (overtightened) COP. Possible improved but a miss was still there. After 2 months of trying other things (several tanks of different fuel, new air filter, mass air flow sensor cleaned) this indy shop again replaced the plugs. Problem solved.
In fairness, I think the owners worker bee got lazy and didn't replace all ten. I say this because at original pick up the owner showed me 7 or so of the plugs. When I asked where the missing ones were he said they were trashed. Question: why would they save some and not all?
Eventually, upon once again returning, I mentioned this - and he remembered it. Of course he said no way, but ...
For the nay-sayers, the plugs weren't Motorcraft - they were Autolite (the actual manufacturer of Motorcraft plugs).
Old 08-17-2014, 06:34 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Quote:
Ahhh yes but the nay-sayers will also say Autolite and MotorCraft are the same plugs, at least in this case.
Old 09-01-2014, 11:59 AM
trinibob's Avatar
posable cause
It seems on start up "now that I have changed the plugs and the fuel filter" the miss or bogging down of the motor in park it seems that the AC pump cycling coincides with the miss or slowing of the motor! This still goes away when the motor warms up so I'm going to see it I can tell if the pump is going bad.
2005 5.4 Triton 3V misfires kbwford 1997-2006 Expedition & Navigator 27 Today 01:30 AM
Rough Idle and Engine Light mwoolard1912 1997 - 2003 F150 10 02-20-2017 01:21 AM
Code P0153 P0133 2000 Ranger just report it as stolen? rogerranger2122 Ranger & B-Series 23 08-08-2016 07:24 PM
"service engine soon" light on after pulling spark plugs jbourne84 1968-2013 Full Size Vans 3 02-02-2016 08:06 AM
04 Escape Misfire and I've Tried Everything I Can Think Of payntertk31 Escape & Escape Hybrid 15 10-05-2015 05:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
