Speaking Of Front End Swaps... - Ford Truck Enthusiasts Forums
Old 08-16-2014, 08:18 PM
wantahertzdonut's Avatar
wantahertzdonut wantahertzdonut is offline
wantahertzdonut is starting off with a positive reputation.
This is more of a curiosity question than anything else, and I couldn't find an answer in a number of searches. So...
I have a 97 F350 2WD. Is it possible to swap the front end out for the solid front axle from a 2wd F450/Superduty? Doing so would be more for looks than much else, since I always liked the high stance of the SD and other 4wd regular cab dually trucks, but never got my hands on one. I would assume a small lift for the rear would be in order to keep the truck level.
If the frame will accept such a swap, would I need to switch to 10-lug wheels too, or is it possible to use my 8-lug brakes on the SD hubs?
Old 08-16-2014, 09:02 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is online now
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
You have coil springs and Twin I beam now. F-superdutys have leaf springs and a Solid I beam axle.
In order to put the leaf springs in your truck you need leaf hangers. The rear ones are easy, they literally bolt in place. Right about where your radius are brackets are. the front, are the tough ones. The F-superduty and 4wd F250/f350 have boxed from frame horns. YOURS are NOT. So you would need to box them to hang the shackle for the leaf spring. Also keep in mind, f-superduty sits about 4" higher than a 2wd F350 So you would need to lit the rear to level the truck out
As for using your 8 lug hubs.... NO GO they use different size stuff so you are STUCK with the 10 lug stuff
Old 08-16-2014, 09:50 PM
That's the exact answer I was looking for. It sounds like a lot more work and expense than it's worth.
'68 F100 2wd Lift & Front Disc Conversion FordStolz68 1967 - 1972 F-100 & Larger F-Series Trucks 1 05-02-2015 08:45 PM
How to convert front brake rotors to 6 lug? DROOPY209 1973 - 1979 F-100 & Larger F-Series Trucks 3 04-29-2015 01:47 PM
Swapping 08 F450 Fat Boy 4.88 rear end into 08 F350 Farvardeen 1999 to 2016 Super Duty 2 07-23-2013 10:24 PM
f350 8 lug to 5 lug 2 wheel drive conversion COMPLETE-CUSTOMS 1987 - 1996 F150 & Larger F-Series Trucks 9 02-01-2012 05:20 PM
1968 F100 Brush Guard, 1968 F100 with 8-Lug l1k2gadd 1967 - 1972 F-100 & Larger F-Series Trucks 4 09-14-2007 06:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
