How to find out what was done to my 400
I have a 1977 400 out of a donor truck that my dad had bought a couple of years ago. The guy that he had bought it from said that it was "built". It has an edelbrock carb, intake, and valve pan covers.
I pulled the oil pan off to verify the casting numbers on the crank and it is a 400. So how do I tell what all was done to it without doing a complete teardown? I should be able to mic the cylinders to see if it was bored, but what size is factory? Can I verify the cam without pulling it?
. May be able to mount a dial micrometer via magnet mount inside the engine, turn engine over, and measure the lobe lifts on the cam and get a good estimate of what it is...
. Using an inside caliper inside the bottom of the cylinder bore, discover the bore size... stock is 4.000" for 351M/5.8L, 400"/6.6L, 351C, 351W/5.8L, 302"/5.0L, and 352"...
. Pistons, hard to tell, maybe a bore scope TV camera would let you see the top of the piston... see if dished, flat, or domed...
. Cpmpression test to see if around 125 psi, 175 psi, 225 psi, etc...
. Driving test... power from 1000-4500 RPMs, 2000-5500, RPMs, 2500-6500 RPMs? Give an idea of cam size...
NMFirstF2504X4
31
09-13-2018 11:29 AM
Augy88066
62
09-16-2014 10:39 PM
