Rear Frame Repaint and Suspension Rebuild
Old 08-20-2014, 03:47 PM
cowmilker08's Avatar
cowmilker08
cowmilker08 is offline
Originally Posted by Diesel_Brad
I sandblast
POR15(2 coats)
Chassis black or tractor black(2 coats)
The results speak for themselves
before
After
Well that looks excellent. Great job. Mine won't look anywhere near that good. My starting point was a lot worse, and I didn't want to sandblast anymore than I had too. I hate sandblasting.
My goal was really just to extend the life of the frame so that it lasts another 5-8 years. Since the factory paint was gone it was rusting away at an alarming speed. I figured at the rate it was going I'd have holes in the frame in 1-2 years.
Alex, remind me, and every spring after the road salt has punished it for 4 months I'll take a picture of it.
Old 08-20-2014, 04:34 PM
Awitte58's Avatar
Awitte58
Awitte58 is offline
I got you Phil! The power of technology will remind me!
I love google...
Old 08-20-2014, 05:05 PM
cowmilker08
Here is the last coat of paint for the frame.
I'm happy with the way it turned out.
I still have to prep and paint the skid plates, etc.
Old 08-20-2014, 07:41 PM
liftnw8z's Avatar
liftnw8z
liftnw8z is offline
(CL) Team Brahma
That's looking good. Personally, I've had good results with flap-discs, wire wheels, and sanding - but I know my show truck is getting the blast treatment this winter to really straighten things up once and for all. The OBS will probably get similar treatment too.
Old 08-21-2014, 04:55 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Originally Posted by Awitte58
Is that the dually teal truck?! I never realized it was a dump bed. Thats freakin' awesome!
I wish I could sandblast everything. Mom would kill me if I did that in the driveway or yard...not sure if they'd care at my apartment complex.
Same with what Nate said. I'd love it if somebody would do the same prep on both halves of a frame, but coat it with different products. Then take pictures a few years down the road. lol
No, that is a F550 i restored a couple of years ago.
As for 2 products on each half of the frame, that would be pointless. the drivers side always gets it worse
The f550 before , during and after
Old 08-21-2014, 07:13 AM
Awitte58's Avatar
Awitte58
Awitte58 is offline
Looks good man! Get some photos of the dirt catchers and places it rusts first then you can compare later.
Hell of a transformation Brad! Do you do this as a side business or just for funzies? hah
Also, why does the driver side get it worse? Is there something there that catches more than the passenger side?
Old 08-21-2014, 10:29 AM
OldWoodsDiesel's Avatar
OldWoodsDiesel
OldWoodsDiesel is offline
man, those frames look good - i'm going to be checking back on this thread as i attempt to make mine look that good!
do you feel the paint penetrated into the crevices where the cross-members are riveted the frame rails? i'd think that'd be the first place rust would start again? or maybe the factory paint was still OK there?
Old 08-21-2014, 12:36 PM
cowmilker08
No I don't think it penetrated between the parts that are riveted to the frame. The factory was gone but the decay in these areas wasn't even close to the worst areas. I'll be sure to get some pictures in those spots too for comparison later. If I were doing a full restoration, not just delaying the inevitable, I would have probably replaced the cross members and painted them before assembly.
The worst rust decay I found was where my DMI bumper hitch bolted to the frame and the rear-most cross member above the front fuel tank.
Brad is right about the driver side being worse, much worse. I don't know why, but its definitely true.
Old 08-22-2014, 04:38 AM
Diesel_Brad
It is my hobby
The drivers side gets it worse due to the constant splash from opposing traffic
Old 08-22-2014, 09:13 AM
Awitte58's Avatar
Awitte58
Awitte58 is offline
Do you still have all of the factory riveted on leaf spring mounts?
The PO had already replaced my rear mounts with some heavy duty bolt on ones. They have a nice drain hole and everything.
It is my hobby
Awesome thanks for the info! Makes sense to me.
Old 08-22-2014, 11:13 AM
cowmilker08
The front mounts are factory. I'm replacing the rear ones. The one's I bought do not have a drain hole. I thought about adding one though.
Old 10-02-2014, 03:19 PM
cowmilker08
Look what the cat dragged in
  #28
Old 10-02-2014, 04:53 PM
427 fordman's Avatar
427 fordman
427 fordman is offline
I like new parts
  #29
Old 10-02-2014, 05:48 PM
Diesel_Brad
Nice!! Superduty springs?
  #30
Old 10-02-2014, 06:27 PM
liftnw8z's Avatar
liftnw8z
liftnw8z is offline
(CL) Team Brahma
New parts are cool. I'm cuing up to buy SD springs myself.
Quick Reply: Rear Frame Repaint and Suspension Rebuild
