Rebuilt Tranny Still Giving Me Trouble
Sensor problem solved. In 1999 the VSS is the same as the ABS sensor. This is not the first time Advance Auto has steered me wrong when using their website for my parts. They also sent me the wrong water temp sensor and it was ship to home only, not available in the store. They were nice, though, and took it back through the store. Now that that is installed my ABS light has gone out too. Now I just keep scanning the truck and see of the tranny thing ceases too.
OK, still having issues and looking for help with this pesky tranny.
Here's where it stands:
Truck has non-chipped tune of some sort. Got reman tranny about a two months ago because other one had a leak. Other than the leak the other one worked fine. Reman tranny seems to be dropping out of high gear into third for no particular reason at highway speeds. It does not do it all the time and stopping and putting into neutral or park for a moment seems to cure it. The tune locks the TC down in high gear and high gear only, did same in old tranny. It throws no codes to AE.
Any suggestions?
Thanks,
Mark
Any suggestions?
Thanks,
Mark
I have not eliminated the tune yet. The mechanic is thinking it is an option. I would have to go to a Ford dealer and have them clear it out and reset to default settings and I don't want to do that if it is not the problem. I like having the tune and I suspect it would cost hundreds to remove and replace it. And since the problem did not exist before the tranny was replaced I'm not inclined to think that is the problem.
Any suggestions?
Thanks,
Mark
Any suggestions?
Thanks,
Mark
If the tune is burned on the PCM then swapping to stock is not cheap and easy. Seems to me if the tune worked before, the problem now is from something new.
Does the light on the shift lever come on? Do you have a real trans gauge? An overheating trans will kick itself out of OD, IIRC.
trevorrules
09-14-2015 03:02 PM
t_chapps
11-07-2006 12:37 PM
iceman06
06-06-2005 06:38 AM
pr0nd3xtr
07-02-2003 09:21 PM
