351w engine build advice - Ford Truck Enthusiasts Forums
Old 08-16-2014, 04:56 PM
Salter70 Salter70 is offline
Salter70 is starting off with a positive reputation.
I just bought a '96 F250 with stock 351w and auto tranny, it had a blown head gasket but that has now been fixed. I am wanting to put the engine tranny combo in my 1970 F100.
I have a set of worked GT40 heads and the upper and lower intake off of a '93 Ford Lightning. And a set of long tube headers.
I'm probably going to punch it out .030 when I build it.
My questions are:
1. How much trouble is it to swap the EFI wiring harness to single throttle body and were could I get the info to do it myself.
2. What cam should I go with?
I'm wanting the HP and torque to be equal to or better that a stock Lightning. Thanks for all the input and advice.
Old 08-18-2014, 01:54 AM
Conanski's Avatar
Conanski Conanski is online now
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
There is no need to change the wiring harness for that intake, you may have to change the connector for the TPS, maybe lengthen and/or rearrange a few wires but that's about it.
Old 08-18-2014, 06:43 PM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
Personally I wouldn't use that efi setup, its going to be speed density efi and doesn't like many mods. you could get a mass air setup from a mustang and have a far cleaner install in my opinion. great motor though, I wouldn't go punching it out unless its necessary. upping the compression though will help improve power.
Old 08-24-2014, 12:13 AM
Blurry94's Avatar
Blurry94 Blurry94 is offline
Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.
You'll need the throttle cable and bracket from a Lightning as well. If you plan on keeping the EGR, then you'll need the EGR spacer and valve from a Lightning. You'll also need to plumb the coolant through the spacer, from the back of the lower intake to the radiator filler neck.
When you get ready to put this combo in you're F-100, I'd recommend using an aftermarket EFI system for the engine and a stand alone transmission controller.
351W Lightning clone engine build TABrinn Performance & General Engine Building 8 05-03-2016 11:52 AM
1995 F150 351W Lightning mass air conversion 95centurion 1987 - 1996 F150 & Larger F-Series Trucks 4 04-08-2016 04:39 PM
Help with engine build dmanic 1978 - 1996 Big Bronco 0 04-08-2015 04:37 PM
Lowering a '92 F-150 - tires? hivoltj 1987 - 1996 F150 & Larger F-Series Trucks 15 12-06-2011 01:12 AM
1996 F-150 351 to 5.4 Swap DaviMac424 1987 - 1996 F150 & Larger F-Series Trucks 8 04-22-2009 07:36 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
