I need a lil help
Old 08-16-2014, 03:53 PM
Fordkindagirl97's Avatar
Fordkindagirl97
Fordkindagirl97 is offline
I need a lil help
I've got a 1997 f150 XLT that my grandpa gave me and said if I fix it I can have it. It has a 4.6 v8 in and it's a 5 speed. I was wondering if anybody knew how difficult it would be to get a motor out of a crown Vic that is the same year and same engine and put it in my truck?
Old 08-17-2014, 09:15 PM
Driver Jim's Avatar
Driver Jim
Driver Jim is offline
Well, that calls for a transmission swap since the Crown Vic ECM is set up to read a TCM (automatic).
You're looking at a good chunk of work either way. Like, a BIG chunk of work.
Old 08-18-2014, 03:53 PM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
You can use the truck ECM and harness. You need to pull the driver's valve cover off both engines and make sure the cam sensor trigger on the cam sprocket is the same. Also make sure they are both Romeo engines or the truck flywheel won't bolt to the CV engine. If they have the same number of valve cover bolts then they are Romeos. If the truck engine is a Windsor then you will need a different flywheel. The Windsor uses 8 flywheel bolts and Romeo has 6. Make sure you install a pilot bearing in the end of the crankshaft.
Shadylady
Modular V8 (4.6L, 5.4L)
08-01-2019 04:48 AM
FX4_FAN
1997 - 2003 F150
09-28-2007 09:20 PM
lurch460
1997 - 2003 F150
05-20-2007 05:52 PM
jm ray
05-11-2007 07:16 AM
stantojl
03-05-2004 07:40 PM
Quick Reply: I need a lil help
