I need a lil help - Ford Truck Enthusiasts Forums
I need a lil help
Old 08-16-2014, 04:53 PM
Fordkindagirl97 Fordkindagirl97 is offline
Fordkindagirl97 is starting off with a positive reputation.
I need a lil help
I've got a 1997 f150 XLT that my grandpa gave me and said if I fix it I can have it. It has a 4.6 v8 in and it's a 5 speed. I was wondering if anybody knew how difficult it would be to get a motor out of a crown Vic that is the same year and same engine and put it in my truck?
Old 08-17-2014, 10:15 PM
Driver Jim Driver Jim is offline
Driver Jim is starting off with a positive reputation.
Well, that calls for a transmission swap since the Crown Vic ECM is set up to read a TCM (automatic).
You're looking at a good chunk of work either way. Like, a BIG chunk of work.
Old 08-18-2014, 04:53 PM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
You can use the truck ECM and harness. You need to pull the driver's valve cover off both engines and make sure the cam sensor trigger on the cam sprocket is the same. Also make sure they are both Romeo engines or the truck flywheel won't bolt to the CV engine. If they have the same number of valve cover bolts then they are Romeos. If the truck engine is a Windsor then you will need a different flywheel. The Windsor uses 8 flywheel bolts and Romeo has 6. Make sure you install a pilot bearing in the end of the crankshaft.
1965 F800 help mountaineer27 Large Truck 1 01-17-2016 01:55 PM
Panel truck frame same as f100 shortbed? Schuyles 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 12-31-2015 04:32 PM
Winter blend milage Grizzly4x4 1999 to 2016 Super Duty 5 12-21-2015 09:37 AM
Frame wheelbase on a f350 is it the same fordf350camper 1957 - 1960 F100 & Larger F-Series Trucks 8 07-24-2015 06:12 AM
My a/c gets cold but not enough to cool can off ? trevorrules 1987 - 1996 F150 & Larger F-Series Trucks 6 04-10-2015 07:54 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
