dipstick motor oil was hot - Ford Truck Enthusiasts Forums
Old 08-16-2014, 04:48 PM
FordRun's Avatar
FordRun FordRun is offline
FordRun is starting off with a positive reputation.
I had my oil changed yesterday
last night I smell oil didn't see no leaks
today I took it back he said it was a little over. so he drain a little out oil
he pulled out the oil stick it was very hot. had even had steam coming off
the dipstick. I have heard that if a ac has leak it could get into your oil
my ac cold air. the hose come in drier is cold. top of drier is wet water
and hose in to ac compressor is cold wet. any ideals thanks
Old 08-16-2014, 05:37 PM
krooser's Avatar
krooser krooser is offline
krooser is gaining momentum as a positive member of FTE.
There's no way a leaking a/c can contaminate the oil….
When the air is hot and humid it's not unusual to have water condensing on the cold portions of the a/c system…
The only time I had problems with a very hot dipstick was with my '95 E-350 with the 5.8 engine. I was hauling 'just in time' auto parts (put on 280,000 miles in 18 months) and I was using the local fleet store's house brand oil made by Citgo. It seemed to be the culprit as I changed to Mobil 1 and never had any problems with high oil temps after that.
I'm not saying the oil is your problem… just giving you my input.
Old 08-16-2014, 06:07 PM
FordRun's Avatar
reply
ty for the reply
I just drain a little bit out oil pan and it was clear. no smell
I hope it was them that did the oil change. and added to much.
Old 08-16-2014, 11:03 PM
FordRun's Avatar
reply
to found out they put in 5w30 havoline oil in
that to low for summer ?
Old 08-16-2014, 11:43 PM
krooser's Avatar
It won't kill your engine but I'd run a 10W30 if you are using dino oil. You can get away with a lighter oil if running synthetic… IMHO of course.
Old 08-16-2014, 11:53 PM
Nothing Special's Avatar
Nothing Special Nothing Special is online now
Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.
Theoretically they should be about the same, since both have a "30" rating hot. But with dino juice they get the "multi-weight" ratings by starting with base oil that gives the low temp "W" rating, and then adding viscosity improving additives to get the higher hot rating. that works OK, but the additives don't hold up as well as the base oil. Main thing that means is that eventually you'll actually have 5W20, then 5W10, then straight 5W. That said, additives are pretty good now, so I wouldn't sweat it with what I would consider normal oil change intervals (3000 miles).
Old 08-17-2014, 02:23 AM
FordRun's Avatar
will try a new oil change . guess 10w30 for the summer ? was told that 5/30 should be
for winter ? I live in Montana
Old 08-17-2014, 09:21 PM
FordRun's Avatar
I did another oil change put in 10/30 castro gtx
still real hot check the oil dipstick was steaming real hot
motor even hot .. inside cab reads normal qauges.
antifreeze is clean. had flushed . when we changed oil 5/30 it was clear
what could it be ? pvc valve ok I drove it about 20 miles doing about 70 engine
was hot. we waited till motor was cool down before driving it. and I did have ac on. thanks
Old 08-17-2014, 09:25 PM
eakermeld's Avatar
eakermeld eakermeld is offline
eakermeld is gaining momentum as a positive member of FTE.eakermeld is gaining momentum as a positive member of FTE.
The OEM temp gauge in the dash tends to be unreliable at best. See if anyone you know has a infrared thermometer you can borrow and do some temp checking with it.
Old 08-18-2014, 08:04 PM
FordRun's Avatar
running hot
changed out the thermostat and pvc today. still motor hot.
put in 195 on pvc guy took a light test heat on hose they was around
178 dg oil sending unit was around 198 dg
took it to parts store pick up new cap for radiator we had all ready had the
thermostat put it back together . when I went to take the cap off it was trying to run over the top. thanks
Old 08-18-2014, 08:30 PM
eakermeld's Avatar
When you had the rad cap off and the engine running, was there a lot of bubbles?
Old 08-18-2014, 09:39 PM
FordRun's Avatar
no bubbles it took a few then it went down so we added more antifreeze
Old 08-18-2014, 09:56 PM
eakermeld's Avatar
That's good! Your head gaskets are probably OK then. Really, those temps are about normal. The oil does get hotter than the coolant. You might check the timing, if it is too slow it can raise EGTs which can make things quite hot under the hood. After that you might check for exhaust restriction e.g. plugged cat.
Old 08-18-2014, 10:00 PM
GoinBoarding GoinBoarding is offline
GoinBoarding is gaining momentum as a positive member of FTE.
What makes you think the engine is running hot? The two temperature readings you posted today at 6:04pm suggest everything is fine. That coupled with the dash gauges not showing any indication of trouble makes me think there may not be any issue at all.
Take a look at where the dipstick tube sits in relation to the exhaust manifold, of course the dipstick is going to be HOT, it runs right next to the exhaust manifold. My dipstick has burnt oil residue on it where it passes by the manifold and has been that way for 10 years at least.
eakermeld's Avatar
One more thing. Try not to get more than a 50/50 mix of antifreeze to water. Too much antifreeze can actually make it run hotter. Strait antifreeze doesn't release the heat like a water mix will.
Leaking AC manifold hose replacement coolfeet 1968-2013 Full Size Vans 17 05-05-2016 12:56 PM
Accumulator drier replacement on 2004 E350 AC coolfeet Cooling, Heating, Ventilation & A/C 0 05-04-2016 10:30 AM
A/C Drier Question ALedbetter1 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 04-08-2015 04:44 PM
AC Receiver Drier (Accumulator?) Leaking Oil cougarman001 Cooling, Heating, Ventilation & A/C 3 09-13-2012 07:06 PM
A/C Receiver Drier replacement pkm83 Explorer, Sport Trac, Mountaineer & Aviator 1 08-02-2006 08:04 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
