dipstick motor oil was hot - Page 2 - Ford Truck Enthusiasts Forums
Old 08-18-2014, 10:10 PM
Encho's Avatar
Encho Encho is offline
The Southernmost Mod
Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.
It seems to be running fine, but check the manifold and exhaust for cracks and leaks.
Old 08-19-2014, 01:35 PM
FordRun's Avatar
FordRun FordRun is offline
FordRun is starting off with a positive reputation.
took it to 2 shops today 1 said might be water pump . other said
it might be the rings
Old 08-19-2014, 02:01 PM
dixie460's Avatar
dixie460 dixie460 is offline
dixie460 has a good reputation on FTE.dixie460 has a good reputation on FTE.dixie460 has a good reputation on FTE.
I don't see why you think there's a problem with your truck. Everything sounds normal to me, and several other members here have said the same thing.
What did you tell the shops that you took the truck to? What makes them think you need a water pump or rings? Are these shops trusted by other people in the area? Some places will sell you stuff just cause they can.
Of course the dipstick is hot! Oil is not only a lubricant, but it also helps COOL the internal engine parts, which means it picks up the heat to get it away from bearings and journals.
And don't fret... what you thought was steam coming from your dipstick was actually just oil vapors. Same stuff you see coming out of the valve cover when adding oil to a hot engine.
Old 08-19-2014, 02:51 PM
blkF250HD's Avatar
blkF250HD blkF250HD is offline
blkF250HD is gaining momentum as a positive member of FTE.blkF250HD is gaining momentum as a positive member of FTE.
Agreed. You're over thinking this, trying to find a problem when there isn't one. Make sure the oil and coolant level are correct, and drive the truck. End of story. If it's not overheating and not leaking any fluids, you have no problem.
If you've ever changed the oil right after driving a vehicle for a while, you'll notice that the oil is hot. It's inside the engine after all. If it didn't get hot the condensation and moisture that naturally occurs wouldn't evaporate, and you'd have water in the oil.
Old 08-19-2014, 04:55 PM
FordRun's Avatar
when I had a oil change I could smell smoke. no oil on manifold or the exhaust
went store that night I could smell oil. I looked on manifold and the exhaust
so I broght truck back they said they must over filled will oil 5/30 so they drain some out. so the next day I am still smelling oil when I get out truck. before that oil change
I never smell oil . as far water pump he was guessing said everything seem to be ok
he been at his shop for years. and other place iam not sure about. but I do thank you for the help and time
Old 08-19-2014, 10:16 PM
eakermeld's Avatar
eakermeld eakermeld is offline
eakermeld is gaining momentum as a positive member of FTE.eakermeld is gaining momentum as a positive member of FTE.
Are you sure it's burnt engine oil you are smelling? Wheel bearing grease and rear end oil smell like that, too.
Old 08-19-2014, 10:31 PM
Encho's Avatar
I bet some oil spilled during the oil change and he's smelling that, as the manifold heat burns it.
Old 08-23-2014, 04:35 AM
FordRun's Avatar
sorry to get back to you all late.
but I took truck in to ford dealer
it turn out to be a bad pvc valve not running hot no more no smoke out of
the oil stick I don't smell oil no more I had them check the whole truck out
they also told me I should replace catalytic converters. I guess for a 94 f150 4x4
with 160xxx miles it still has some life left in her. but I wanted to thank you all
for help and replys
Leaking AC manifold hose replacement coolfeet 1968-2013 Full Size Vans 17 05-05-2016 12:56 PM
Accumulator drier replacement on 2004 E350 AC coolfeet Cooling, Heating, Ventilation & A/C 0 05-04-2016 10:30 AM
A/C Drier Question ALedbetter1 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 04-08-2015 04:44 PM
AC Receiver Drier (Accumulator?) Leaking Oil cougarman001 Cooling, Heating, Ventilation & A/C 3 09-13-2012 07:06 PM
A/C Hell once again (NEED HELP) zarillus 1997-2006 Expedition & Navigator 11 05-09-2008 07:03 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
