6.0 Problem, Can anybody help please?
#91
#92
Here's a better copy of the operating values list.
https://www.ford-trucks.com/forums/a...1&d=1364848489
#95
#96
Truck is all sorted and running great, however it is still showing a pending code P2262, which was the original code. I cleared it and it comes back immediately, so I am a bit confused by that. EBP, Baro and MAP are all within 0.5, EOT and ECT are within 3 or 4 degrees of each other and between 190 and 205 (ambient temperature was 94F)
The other thing that's confusing me is the voltage. On the Scangauge it's showing 0.3 volts less than my dvm on the battery terminals. Dvm reads 12.8, key off. With key on and glowplugs on, it reads 12.12 but Scangauge only 11.8 - which I believe is a bit low. It's a decent meter, not a cheap one. I put a cheap analogue meter on to verify and that concurs with the dvm. Has anyone else had this discrepancy with a Scangauge?
Cheers
Andy
Cheers
Andy
#97
on
Scan gauage is picking up voltage from the dlc. It will be a little different then hooking a dvom up to a battery.
Ebp, map and baro should be with in 0.5psi koeo. They should all read around 14.5 psi.
Pull and check your egr valve for debris and varify its completely closed. Next step is varifing you have no boost or exhaust leaks. After that pull and clean turbo thats my best guess at this time.
#98
#100
If you're using the ScanGauge to clear codes, even something straight forward like a glow plug won't clear unless you shut truck off, turn key to on (no start), clear code, then start truck. Sometimes depending on the code, you even have to turn key off after clearing and then crank/start.
#101
PDX_Doug
04-03-2008 02:50 PM
