KOEO 48.8v
Buzz test (switching from ignition off to ignition on) the meter read 26.88v, 25.7v, 0.0v, then 48.8v
Cranking voltage never moved from 48.8v.
You can only fix one thing at a time, start with easy and knowen issues then work up.
If you check ficm voltage at 2000 rpm you may find it low volting there as well.
The ficm controls the injectors, poor injector performance will kill boost.
If you or someone you know is handy with a soldering iron you can possibly do it yourself. Many times the components are still in specification and just need to be reconnected to the circuit board.
You seem like a very knowledgeable person who understands how to repair things.
Google how to solder on circuit boards to get a good idea of what to expect and how to do it. Take your time. I would suggest a magnification light so you can see what your doing.
