injectors keep blowing the o ring off - Ford Truck Enthusiasts Forums
Old 08-16-2014, 03:59 PM
Toyman's Avatar
Toyman Toyman is online now
Michigan Chapter Ldr
Toyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputation
It's a 2006 F250 crew cab short box lariat. has had egr delete, studs, and gaskets. It now seems to be eating injectors. randomly they will just blow and it runs like crap. All of the injectors were replaced when the studs and gaskets were done. which is less that 10,000 miles ago.
Any ideas what could make this happen?
Old 08-16-2014, 04:03 PM
bismic's Avatar
bismic bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
What injectors were installed (where did you get them)?
What is your fuel pressure?
Old 08-16-2014, 06:50 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
Most common cause is not using a torque wrench. Over torqued will damage the hold down bolt, giving you the same issue as under torqued
Old 08-16-2014, 06:55 PM
Rusty Axlerod's Avatar
Rusty Axlerod Rusty Axlerod is online now
Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.
Maybe tweaked injector hold down, or they didn't clean the oil out of the injector hold down bolt holes causing incorrect torque reading?
2003 injector issues tjustice 6.0L Power Stroke Diesel 19 01-10-2016 11:02 AM
Stumped... no more black smoke! neovb 6.0L Power Stroke Diesel 2 09-21-2015 09:27 PM
Finally getting studded. mxer0022 6.0L Power Stroke Diesel 5 07-13-2014 11:15 PM
Entire Gasket Kit? AndeyHall 6.0L Power Stroke Diesel 27 03-07-2012 10:49 PM
head studs without removing the head? 06stroke 6.0L Power Stroke Diesel 20 10-08-2008 03:06 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
