Add new exhaust to '94 PS Diesel - Ford Truck Enthusiasts Forums
Old 08-16-2014, 03:24 PM
happytroells happytroells is offline
happytroells is starting off with a positive reputation.
Smile Add new exhaust to '94 PS Diesel
Will there be any problems adding a 5" Diamond Eye exhaust to the '94 7.3L Power Stroke? We have researched to find that the engine is too old for the new emissions requirements such as EGR and DPF. Is there anything else that we are overlooking before changing to a bigger exhaust?
Old 08-16-2014, 06:13 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
5" is going to be VERY tight and a waste.
You only have a 3" outlet out of the turbo and the down pipe is a 3"(all you can fit without cutting and dog housing the firewall.
SO anything bigger than 4"(not to restrict at the bends) is complete waste
I recommend Flo-Pro 4" stainless system
And stay away from MBRP
Old 08-16-2014, 07:55 PM
Thank you for your help.
Old 08-17-2014, 02:59 AM
BiGGreen350's Avatar
BiGGreen350 BiGGreen350 is offline
BiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant future
Any reason to stay away from mbrp? is it just to stay away for the obs 7.3 or the superduty aswell?
Old 08-17-2014, 08:50 AM
Quote:
It fit like complete crap. I did the typical firewall mod for the DP, bit is LAID on the floor. I also had to remove the passenger crossmember brace and NOT reuse it.. Next was EVERY hanger had to be modified to work. Then the tailpipe hit the rear spring.
I took it off, threw it is the scrap pile and bought the Flow pro stainless kit for LESS money then the MBRP aluminized kit.
I have no clue on SD fitment
Old 08-17-2014, 05:30 PM
sounds like we will stay away from them for the 550s then! thanks!
sorry for the highjack OP
Old 08-18-2014, 12:23 PM
What do you mean when you say that the 5" will be a very tight fit? The pipe I was looking at has a 3" downpipe to a 5" exhaust . Where would it become a tight fit?
Old 08-18-2014, 02:36 PM
429SCJ 429SCJ is offline
429SCJ is starting off with a positive reputation.
Have to agree.Installed MBRP on my 03 6.0 last week and it fits like crap.Mid-pipe is not bent right.Hits on spring shackle and the hangers are a joke.
Old 08-18-2014, 05:01 PM
Quote:
Near the trans crossmember, The driveshaft, axle, bed, fuel tank and spare tire
You have to remember, the truck was designed to have 3" exhaust. And there were clearances made for such. You do away with all the clearance with a 5" exhaust
Old 08-19-2014, 05:14 AM
HOOTs95PSD HOOTs95PSD is offline
HOOTs95PSD is starting off with a positive reputation.
I put the Stainless Steel "Diamond Eye Exhaust" Turbo back 4" on mine. It fit very well and I got it for $320 bucks shipped to my door. Every hanger worked just fine with no mods needed to them. I had to cut to make room for the downpipe and You need to remove the catalytic converter mount( mine was a delete kit) and the rear fuel tank strap needs the excess hang over on it trimmed off. I still need to do this I can hear it rubbing. If I knew I could of cut the muffler unit just a bit to move it forward an inch or so I would of done it also.
Definitely should of done this 5 years ago.
anyone have exhaust recomendations 8vettes 1978 - 1996 Big Bronco 2 11-11-2015 08:25 PM
94 mustang gt 5.0 fuel pressure new7.3owner Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 6 08-18-2014 11:25 AM
94 mustang gt 5.0 bogging and back firing new7.3owner Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 08-09-2014 01:15 PM
94 mustang gt 5.0 throttle body new7.3owner Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 07-27-2014 05:39 PM
Stacks or back exhaust? Ranch Rig 1994.5 - 1997 7.3L Power Stroke Diesel 23 07-25-2014 10:17 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
