Was thinking about sellin my CCLB 7.3 5 speed. - Ford Truck Enthusiasts Forums
Old 08-16-2014, 11:24 AM
DanielT28's Avatar
DanielT28 DanielT28 is offline
DanielT28 is starting off with a positive reputation.
I just couldn't bring myself to do it. I was offered 13k as is. 170k miles on my truck.
And our trucks are getting rare to find. Especially in great condition. And it's a crew cab 5 speed ! I get so many compliments and so many questions on my truck that it's unbelievable.
I was going to sell my truck for a Dodge Cummins but I just couldn't bring myself to get rid of my ford. And go into 15-20 k of debt. My trucks already paid for. And I've put about 10 grand into it.
Here is a list of things id still like to do to my truck
-better turbo (I want something that gives me more power. But I don't want something that is going to tear my truck apart. ) any suggestions on turbo ?
-lift springs in rear to eliminate blocks
-**already have stage 1 rosewoods**
-e fuel at some point
-drop Pitman arm
-possibly a redhead steering box
And idk what else
Old 08-16-2014, 11:33 AM
IDMooseMan's Avatar
IDMooseMan IDMooseMan is offline
IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.
My truck has an E4OD. I'd like to have the 5-spd. Either way, I have no plans on getting rid of her. I'd like to do more modifications (injectors, turbo, etc.), but that isn't going to happen in the near future.
I believe the S366 is a popular turbo upgrade. Try a search for "Turbo upgrade" or something similar. You'll find many results on this topic. Contact some of the site sponsors, too. They'll have lots of ideas for you.
Old 08-16-2014, 01:17 PM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
I said the same thing a couple months ago when a guy offered me 18k for my dually. I turned it down. Well he has made another offer so the dually will have a new home in a couple weeks.
The new offer is 16k, I keep my built engine and put the original 53k mile engine back in.
Old 08-16-2014, 01:25 PM
stainlessstroker95's Avatar
stainlessstroker95 stainlessstroker95 is offline
stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.
Old 08-16-2014, 02:03 PM
DanielT28's Avatar
I don't see where the spring kit is on that site ?
Old 08-16-2014, 02:07 PM
DanielT28's Avatar
Well I clicked on the link on my iphone. Guess I may have to use a computer
Old 08-16-2014, 03:03 PM
DanielT28's Avatar
How do I know how much lift I have in my truck?
There is a block that's 4 inches tall I believe is the stock one. And there's also a block that is 3 inches tall that I think is the aftermarket one on top of the 4 inch block.
So that means I only have 3 inches of lift right?
So Wouldn't the four and a half in shackles make it sit higher in the rear than the front?
Old 08-16-2014, 04:21 PM
fordpride's Avatar
DO NOT STACK BLOCKS
That's asking for unsafe things to happen
Old 08-16-2014, 05:44 PM
DanielT28's Avatar
On the rear it's already lifted with blocks. I want to fix the axle wrap I'm getting.
I was just wondering what size of shackle reverse to get. I believe my truck is lifted 3". But not sure. They sell 4.5 & 2" kits. And I want my truck to sit level. Not rear higher then fromt
Old 08-16-2014, 08:43 PM
So take out the stock four inch and leave the three inch in there.
Old 08-16-2014, 08:54 PM
fordpride's Avatar
If you want fix the axle wrap, get rid of the stacked blocks and use lift springs with traction bars. Stacked block are a good way to get you or someone else injured or killed.
I've seen truck spit stacked block out.
Old 08-16-2014, 10:16 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is online now
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Skip the SKY stuff. Look at RUFFSTUFF. They make a QUALITY product. Especially when you consider the weight of these trucks
I have a set on my bronco
O, did I mention it also gives you the RIGH pinion angle too
Old 08-17-2014, 01:39 AM
DanielT28's Avatar
Did you have to re drill for the ruff stuff or bolt right on ? (From the licit looked like you had to do some grinding or something ) I just want it to be simple and correct. And safe )
Old 08-17-2014, 08:43 AM
Yes. I had to drill all 4 holes. I just tack welded one in place and set the weight of the truck on it to make sure I had good shackle angle. (it was close but not quite right). SO I ground the spot welds off and repositioned. Then drilled my 4 holes.
Old 08-18-2014, 10:33 AM
jchosler's Avatar
jchosler jchosler is offline
jchosler is starting off with a positive reputation.
Quote:
Originally Posted by stainlessstroker95 View Post
Did this kit on mine and it almost got it leveled. I always have blocks sitting around the garage due to the buggy builds always set up on one ton axles. I kept swapping blocks in till I got the correct height then shimmed for correct driveline angle. Its perfect now
Help me outfit my Ex for a trip to Alaska 2005 Ex Limited Excursion - King of SUVs 61 04-10-2016 05:50 PM
Gauge Question Raleigh234 1994.5 - 1997 7.3L Power Stroke Diesel 15 02-11-2016 06:10 PM
Help me navigate a bad purchasing decision JoeF250 6.0L Power Stroke Diesel 42 12-05-2015 01:17 PM
Paint Question Just 5 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 06-08-2014 11:40 AM
Head Bolt, FML. dimerol Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 15 06-05-2011 10:22 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
