Parking Light on 1AAuto '08 lights. - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 08-16-2014, 10:15 AM
Technologiq's Avatar
Technologiq Technologiq is offline
Avid GM Hater
Technologiq has much to be proud ofTechnologiq has much to be proud ofTechnologiq has much to be proud ofTechnologiq has much to be proud ofTechnologiq has much to be proud ofTechnologiq has much to be proud ofTechnologiq has much to be proud ofTechnologiq has much to be proud ofTechnologiq has much to be proud ofTechnologiq has much to be proud of
Purchased a set of the lights with the chrome and ptm caps. They installed great without the need for the adapters. Whole process took about 5 minutes per mirror. They work great for heat and the turn signals but I've noticed I never see the lower bulb go on which apparently it should when I have my headlights or parking lights on.
Anyone point me in the right direction to get this fixed? Thanks!
Old 08-16-2014, 10:27 AM
william_04_x's Avatar
william_04_x william_04_x is offline
william_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputation
Did you check out the write up in the tech folder, Jeremy? You'll need to add the running light circuit to the new mirrors. It can be tapped from the harness as shown, or the HL switch itself.
Old 08-16-2014, 11:10 AM
johntpr johntpr is offline
johntpr is gaining momentum as a positive member of FTE.johntpr is gaining momentum as a positive member of FTE.
Old 08-16-2014, 08:39 PM
Avid GM Hater
Thanks guys. I knew the install went a little too easy
Old 08-16-2014, 08:50 PM
The rest is cake too. Fishing through the dash, and door boots isn't hard. Tap the brown wire on the HL switch after verifying it's correct with a test light. My memory is a bit fuzzy. I did this swap with OEM mirrors on my buddies truck. That was back in January, 2008. He wanted them for Feb dyno day. More horshpower.
Name:  2-2-2008 DynoDay 017.jpg
Sent from my Moto X using IB AutoGroup
No park lights or plate light. htownoag 1987 - 1996 F150 & Larger F-Series Trucks 0 12-19-2015 05:58 PM
Front Parking light Assembly twigs 1961 - 1966 F-100 & Larger F-Series Trucks 34 06-05-2015 12:06 PM
Parking Brake Switch Problem? stpete Excursion - King of SUVs 15 11-12-2014 07:13 AM
54 parking light wiring MIKEDEL 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 10-26-2014 09:58 AM
front parking lights not working wrd0225 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 09-30-2014 11:53 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
