Dash speaker wiring?? - Ford Truck Enthusiasts Forums
Old 08-16-2014, 01:39 AM
Scoop531 Scoop531 is offline
Scoop531 is gaining momentum as a positive member of FTE.
2 wires one black one black with blue dots. My question what wire is + what wire is - and clue
Old 08-16-2014, 08:35 AM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
I looked at the factory wiring diagram and it doesn't specify which is + or -.
Old 08-17-2014, 09:13 PM
Yeah did the same I even pulled out the dealership service manuals and couldn't locate it either.
Old 08-17-2014, 11:23 PM
From the speaker to the unit. Someone cut the harness we were gonna hook the center speaker back up to a newer head unit since it looks intack still just figured I'd ask before I guessed
Old 08-18-2014, 11:17 AM
miz miz is offline
miz is starting off with a positive reputation.
it doesn't really matter, if it's hooked up backwards the signal will just be 180 degrees out of phase. I guarantee you won't be able to tell any difference.
Old 08-18-2014, 11:24 AM
miz miz is offline
And if it does sound weird all you have to do is flip the wires back around. either way you won't hurt anything.
Old 08-18-2014, 12:21 PM
Twanstyle Twanstyle is offline
Twanstyle is starting off with a positive reputation.
I agree with miz
as a standard rule I go solid as neg and spoted or striped as pos
I also test the speakers before mounting (I understand yours is already mounted) so I would suggest when you start on the new head unit take the left or right front door speaker set it on the dash try it on both sides of the dash speaker you can hear the difference more with the low frequencies
Old 08-18-2014, 03:41 PM
77&79F250's Avatar
77&79F250 77&79F250 is offline
Used OEM parts guy
77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future
Stock speaker and radio? Read this, ask this guy.
The guy I used is in Scottsbluff Nebraska. His name is Gene Cochran, and he works out of his house. He's a crusty old codger, but does some tremendous work. While he had the radio apart, he updated some of the internals and cleaned the heck out of everything. My total bill was $25! His number is 308 632-2520 (I checked with him at the time I collected my stereo, and he was OK with giving his number out)
He also lined me out on the manner in which the old radios were wired (mine at least). The speakers are in series meaning positive from radio to positive on speaker #1, negative from that speaker goes to positive on speaker #2. Negative from Speaker #2 goes to Negative on stereo. Now the stock stereo rocks as loud as the little 51/2 speakers can handle!!!
While it's there you might see if he'll wire in an aux input jack. I had it done with mine, and it allows me to run my I-pod through it. Basically when the I-pod is connected it becomes the antenna source. Cost in parts was under $5. I set mine on a 12" extension so I could just drill a small hole in the dash by the ashtray, which I'm turning into a covert charging / storage station for my phone and I-pod. won't cost much more.
Old 08-18-2014, 03:44 PM
Awesome. I like that
speaker wire color Brian Fulcher 1987 - 1996 F150 & Larger F-Series Trucks 0 04-29-2015 09:08 PM
reverse camera power wire for pioneer head unit tjc transport Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 1 11-28-2014 09:41 AM
Instrument panel lights 460harris 1973 - 1979 F-100 & Larger F-Series Trucks 5 10-06-2014 05:06 PM
4 wire sending unit to a 2 wire plug NY Signman Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 10-03-2014 11:46 PM
1978 alternator wiring shotgun2 1973 - 1979 F-100 & Larger F-Series Trucks 17 08-28-2012 05:19 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
