I know, trailer tires again. Heavy 16's - Ford Truck Enthusiasts Forums
Old 08-15-2014, 10:14 PM
Ferguson65's Avatar
Ferguson65 Ferguson65 is offline
Ferguson65 has a brilliant futureFerguson65 has a brilliant futureFerguson65 has a brilliant futureFerguson65 has a brilliant futureFerguson65 has a brilliant futureFerguson65 has a brilliant futureFerguson65 has a brilliant futureFerguson65 has a brilliant futureFerguson65 has a brilliant futureFerguson65 has a brilliant futureFerguson65 has a brilliant future
So I lost a tire on my gooseneck this weekend. The trailer is a 2006 with original tires. There's nothing for them to mess up if they let go, and it doesn't go cross country so I've let it be. It's got Load Star (Kenda) Karrier H/D's, 235/85R16 load range G's on it now. The tire that went looks like a broken belt in the tread, but nothing came flying off of it, despite steel cord sticking out of the tread.
Is anybody running this size and load range on their trailers? It appears the G is obsolete and replaced with F that has a higher load rating. Anybody running other brands with good luck? It's not a cheap tire size or load range, so if there's something better out there I'd consider it........................... Really more concerned with quality over price, though some of the prices I've been quoted are nuts.
Old 08-15-2014, 10:20 PM
bigredtruckmi's Avatar
bigredtruckmi bigredtruckmi is offline
bigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant future
Check tirerack.com for pricing and they have reviews on tires. Good luck!
Old 08-17-2014, 04:57 PM
terryknight's Avatar
terryknight terryknight is offline
terryknight has a great reputation on FTE.terryknight has a great reputation on FTE.terryknight has a great reputation on FTE.terryknight has a great reputation on FTE.terryknight has a great reputation on FTE.
i run LT 235/85-16 tires on my GN and car trailer. th ones on the GN are getting close to replacement. i was going to try greenballs next they seem to be highly recommended
on the bottom of page 7
Greenball Corp, 2014 - 2015
Old 08-17-2014, 07:04 PM
wingedone's Avatar
wingedone wingedone is offline
wingedone has a very good reputation on FTE.wingedone has a very good reputation on FTE.wingedone has a very good reputation on FTE.wingedone has a very good reputation on FTE.
What is the weight rating of the axles?
Old 08-17-2014, 07:18 PM
Ferguson65's Avatar
Quote:
7K each. An E rated tire is pushing max at capacity, but the original G's were rated at 3700 or so each. The current F is rated for 39xx each now. Don't need that high, but rather not be pushing the E's to max either.
Old 08-17-2014, 08:40 PM
Chalkie Chalkie is offline
Chalkie is starting off with a positive reputation.
You can get a load range G. Goodyear G614 RST. They are very pricey though. I have been shopping them as I want something heavier duty on my coach. They run $350+/each.
The Greenball's mentioned above do seem to have good reviews, I am researching them as well. I think the Greenball's are made in China, the Goodyear is made in the U.S. and that may sway my decision more than price.
Old 08-17-2014, 09:49 PM
if you can find where it says the goodyears are made in the USA i would like to see it. i know they used to be, but i thought they recently also moved to manufacture in china
Old 08-17-2014, 09:56 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
I actually run the G614s on the front of my truck for mileage, and the ones I got say 'made in USA' on them, but I got them used and the DOTs are on the inside so I have no idea when they were actually made.
If you have time to play with, you may be able to track down a used set from a fleet service company or used tire store. I got the pair for my truck from a little shop in Tacoma for $100 each.
Old 08-18-2014, 03:43 PM
wingedone's Avatar
Quote:
Yours is a special case, but generally in an RV, 7k axles mean G rated tires or better (some run H rated 17.5's versus the G 16's).
An ST G rated tire is much cheaper than an LT. But they are all made in China. And they all have a higher chance of going boom. Not all of them. But it's like playing Russian roulette with more bullets in the gun.
Generally, G614's are an excellent tire, but stupid pricey. An alternative in a Sailun S637 (G rated 16 inch) tire seems to be getting a lot of early good press on the net. About half the price of the Goodyear's. Unsure of origin.
Goodyear G614's seem to be well warrantied by the company though. Several people that had a blow, had the cost of all repairs paid for by Goodyear. Not going to find that with another company.
The current G614's are made in the US.
Old 08-18-2014, 06:46 PM
spud57's Avatar
spud57 spud57 is offline
spud57 is gaining momentum as a positive member of FTE.
Lot of the folks over at RVNet recommend Michelin Ribs over the China bombs. Not being an ST tire, they are rated higher than 65 MPH.
Old 08-20-2014, 09:03 AM
Quote:
You got me curious so I got an answer from the horse's mouth, so to speak. I emailed Goodyear and this is the answer I got:
Quote:
Sent by: Goodyear Tire & Rubber Company Consumer Relations 728 200
Innovation Way Akron, OH 44316-0001 Voice #: 800.321.2136 Fax #:
330.796.6829
Thank you. That tire is manufactured in Topeka, KS.
Jessica - Consumer Relations
Goodyear World Headquarters
Old 08-20-2014, 09:18 AM
Quote:
The Goodyear G614, like the Ribs, are sized as LT tires, even though Goodyear specifically says they are a tire for trailers. They are, however, about $50 more per tire than the Ribs. But then, the Ribs are not available in a load range G tire, which was Ferguson65's original question.
He needs the heavier tire to replace what he has, I want the heavier tire because I don't fully trust what I have.
Old 08-20-2014, 11:38 AM
rvpuller's Avatar
rvpuller rvpuller is offline
rvpuller is a splendid one to beholdrvpuller is a splendid one to beholdrvpuller is a splendid one to beholdrvpuller is a splendid one to beholdrvpuller is a splendid one to beholdrvpuller is a splendid one to beholdrvpuller is a splendid one to beholdrvpuller is a splendid one to behold
I had 2 full sets of the Goodyear 235/85/16 G tires on our trailer, the first set lasted about 25K miles before one lost its tread, still had 110 lbs of air just no tread. The second set lasted 2.5 years and about the same miles before one of them was losing its tread so I made a change. We now have set of Sumitomo 215/75/17.5 H tires and our tire problems stopped, now I just have to replace them because of age. You can buy steel or metal 17.5 wheels, aluminum is around 265 and steel runs around 150 each. The Sumitomo that I just replaced from age and axle alienment was $300.15 mounted balanced and tax.
Denny
Old 08-20-2014, 01:18 PM
Quote:
good to know
Old 08-29-2014, 09:57 PM
Ferguson65's Avatar
After a bit of digging around online, and calling some of the local truck tire places, I think I'm going to go with these (that Wingdone mentioned)............Sailun S637 Sailun Commercial Truck Tires: S637 Premium Regional All Position . Going to throw 2 on for now, as my R/F tire on the trailer looks like the L/F did before it let go...........
Seem to have good reviews from around the web, I can have them mounted for around $185 each, which is less than I'm going to pay for just the Karriers alone. The GY G614's are just too much for a trailer that doesn't get used all the time, and doesn't really have anything fragile to damage.
Time will tell, but these seem to be one of the better China tires.
TYRES in AUSSIE Diesel Submariner Australia Chapter 1 06-14-2013 01:34 PM
Time for tires. Need your suggestions!! clintusaf 1999 - 2003 7.3L Power Stroke Diesel 32 02-02-2013 08:07 PM
Found NOS Big Truck Traction Tires - Date Code Question truckdog62563 1948 - 1956 F1, F100 & Larger F-Series Trucks 30 12-31-2010 07:18 PM
Mixing Load range D and E on E-350 dually? spikedog General Automotive Discussion 11 07-13-2010 01:06 PM
Green Diamond Tires Lane Dexter Brakes, Steering, Suspension, Tires, & Wheels 10 12-07-2006 07:28 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
