Coolant types - Ford Truck Enthusiasts Forums
Coolant types
Old 08-15-2014, 08:16 PM
bigcountry1009 bigcountry1009 is offline
bigcountry1009 is starting off with a positive reputation.
Coolant types
Would it hurt to run a heavy duty diesel coolant in my '84 F-150? Or in my wife's Dodge Caravan for that matter. I already run a 15w-40 diesel oil in them.
Old 08-15-2014, 08:29 PM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Some of the diesel coolants do not have silicate in them. That protects the aluminum parts in your cooling system, which can be the radiator and the replacement heater cores are usually aluminum.
If it's low silicate coolant, make sure it has some other stuff in it to protect the aluminum.
Help... No or little heat JasonGlove 6.0L Power Stroke Diesel 19 08-21-2015 11:33 AM
Coolant Filter Pros's Con's troy676 6.0L Power Stroke Diesel 5 09-21-2014 06:52 PM
Using coolant "flush" detergent? bigcountry1009 1999 - 2003 7.3L Power Stroke Diesel 19 08-17-2014 09:12 PM
Coolant question... Why only Ford coolant? Allstar recovory 6.4L Power Stroke Diesel 3 12-24-2013 01:31 AM
Coolant and coolant additaves dventoza 1994.5 - 1997 7.3L Power Stroke Diesel 2 02-09-2011 12:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
