89 cam and motor swap need some advice! - Ford Truck Enthusiasts Forums
Old 08-15-2014, 08:07 PM
brandon mauldin brandon mauldin is offline
brandon mauldin is starting off with a positive reputation.
So I picked up a 302 roller motor the other day with only 60,000 miles on it for 250$! I'm gettin it ready to go in my 89 f150 on 42s so I figured while I got the time and got it out why not freshin it up a bit and give it a little more ummff! Well so far I picked up a set of gt40p heads and and I wanna add a mild cam, I don't want anything major it'll still be on the speed density system and I do drive it on and off the road quite a bit. Iv been lookin at the comp XE264HR cam and it seems to be pretty much what I'm lookin for. Question is will this cam alone work with stock gt40p heads or am I gonna need to change springs/lifters/rocker arms.. Ect ect..? I'd like to keep them stock if possible and also I'll be running long tube headers what kinda gains will this set up give me?? Thanks!
Old 08-16-2014, 08:20 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
That will run on SD but I think it will be pushing the limits of the system It would be a good idea if you installed a wideband O2 sensor to keep an eye on the Air/fuel ratio, if it goes lean at higher rpms you can try an adjustable FPR to raise fuel pressure a little from stock.
As for the heads, I don 't believe the stock springs will support the lift that cam generates so an aftermarket spring setup will be needed. No need for anything but stock rockers and pushrods however.
Old 08-16-2014, 08:39 AM
F350 1990's Avatar
F350 1990 F350 1990 is offline
F350 1990 is starting off with a positive reputation.
Your hard efforts may be wasted on that Speed Density system.
Old 08-16-2014, 04:27 PM
Well on comps website it says that cam should be used with 1.7 rockers and I believe that the stock ones on gt40p heads are 1.6.. ? So if I use it with the stock rockers it'll bring the lift of the cam from .544 to like .512...right? So would I still need new springs? and second I read everywhere people say stay with a lsa of 114* with speed density but this cam has a lsa of 112*.. Would that cause a problem?
Old 08-23-2014, 09:47 AM
Well iv got the cam in and now my pushrods seem too short.. And also since I'm using the stock 1.6 rocker arms with the cam will I still need to upgrade valve springs? I really want to stay with the stock ones if possible..
Old 08-23-2014, 11:02 AM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Old 08-23-2014, 11:07 AM
I knew if I went with the 1.7s if have to upgrade but I was hoping that with 1.6s I could get away with it. If I decide to go 1.7s anyway why are some good springs? Comp recommends some dual springs but I'd rather stay with some single trick flows or somthin that will work with my heads how they are
Old 08-23-2014, 11:09 AM
Conanski's Avatar
Quote:
No it doesn't say that.. it says it can be used with 1.7 rockers.
Yes that is right on both counts.
Yes, and you need to check that they don't experience coil bind at full lift.
What cam did you buy, the XE264HR-12 or the XE264HR-14? You should have bought the -14.
Old 08-23-2014, 11:12 AM
I bought the xe264hr-12.. Would you recommend I stick with the stock 1.6 rockers and just upgrade springs and push rods or get the 1.7 rockers and upgrade springs and pushrods?....
Old 08-23-2014, 11:15 AM
Conanski's Avatar
You are using roller lifters with that cam right?
Stock springs may "work" but they are pretty weak and will allow valve float at higher RPMs, stiffer single springs are my suggestion as doubles will most likely require machineing of the spring seats.
Old 08-23-2014, 11:18 AM
Yes I'm using the stock roller lifters they were in great shape. The motor was out of a 89 grand marqui. And what are some springs you would recommend?
Conanski's Avatar
1.7 rockers are wasted on these heads as they don't flow any more past 0.500" lift, so you're just spending money for no gains.
Old 08-23-2014, 11:20 AM
So upgrade springs get longer push rods and call it a day?
Old 08-23-2014, 11:47 AM
Conanski's Avatar
You shouldn't need longer pushrods, what made you think the ones you have a too short?
Old 08-23-2014, 12:00 PM
I put the cam in last night and literally the push rods are wayyy loser than they were with the old cam like I can grab the lose ones wiggle them around and even up and down a little
Cam with speed density brandon mauldin 1987 - 1996 F150 & Larger F-Series Trucks 2 08-18-2014 10:55 PM
Should I upgrade to a four barrel intake manifold jsutton Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 17 10-14-2013 10:20 AM
GT40 heads - do I need a new cam? BossFan Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 13 09-19-2013 11:52 PM
GT-40 Heads what is a good price???? RFAgrasshopper Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 4 05-09-2012 10:15 PM
302 4x4 build xc4jokestomper 1987 - 1996 F150 & Larger F-Series Trucks 20 05-07-2012 10:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
