89 cam and motor swap need some advice! - Page 2 - Ford Truck Enthusiasts Forums
Old 08-23-2014, 01:11 PM
brandon mauldin brandon mauldin is offline
brandon mauldin is starting off with a positive reputation.
I thought the stock ones were supposed to work too but they are deff short idk what the deal is
Old 08-23-2014, 01:49 PM
Conanski's Avatar
Conanski Conanski is online now
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Yeah that is strange, I got the same cam(XE264HR-14) in a 5.0 roller with stock heads and the stock pushrods were the right length. How much too short are they? And did those pushrods come with that motor?
Old 08-23-2014, 01:54 PM
Yes the push rods were the same ones that were in it and I never measured them but they are deff shorter than before. I could spin them before but now I can pretty much wiggle them around. There's not much difference in the 12 that I have and the 14 you have right?
Old 08-23-2014, 02:02 PM
Conanski's Avatar
No the cams are identical except for the lobe separation angle. You need to make sure the lifters aren't collapsed when testing for pushrod length, one simple way to do that is to dismantle one(be careful there is a spring inside) and replace the guts with washers so that the plunger cannot collapse when the rocker is torqued down. That simulates full oil pressure so you can get an accurate measurement. It is possible you need slightly longer pushrods.. different heads so anything is possible.
Old 08-23-2014, 02:59 PM
Well idk the same heads and same push rods worked fine with my stock cam... Maybe I was just in a hurry and put somthin back together wrong idk I'll look at it again when I get home
Old 08-23-2014, 03:37 PM
You recommend any good springs?
Old 08-23-2014, 04:06 PM
I think I may have found the problem, the cam I have the (xe264hr-12) has a lift off .544 the one you have (xe264hr-14) has a lift of .512.. Is that why your stock push rods worked and mine didn't..?
Old 08-23-2014, 04:47 PM
Conanski's Avatar
Quote:
No and no. Both of these cams produce 0.512" lift with 1.6 rockers and 0.544" lift with 1.7 rockers, and that has no effect on pushrod length.
Old 08-23-2014, 04:55 PM
Quote:
Hmmm this beats the **** outta me lol
Old 08-24-2014, 02:26 AM
Hey man when I got home I decided to take a drill and old distributer gear and pump up the oil in the motor, when I started to pump it all the lose push rods tightened up and actually seemed like they were where they needed to be! But the moment I stopped pumping the oil the pushrods got really lose again...?
Cam with speed density brandon mauldin 1987 - 1996 F150 & Larger F-Series Trucks 2 08-18-2014 11:55 PM
Should I upgrade to a four barrel intake manifold jsutton Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 17 10-14-2013 11:20 AM
GT40 heads - do I need a new cam? BossFan Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 13 09-20-2013 12:52 AM
GT-40 Heads what is a good price???? RFAgrasshopper Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 4 05-09-2012 11:15 PM
302 4x4 build xc4jokestomper 1987 - 1996 F150 & Larger F-Series Trucks 20 05-07-2012 11:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
