3 questions - thanks - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-15-2014, 09:07 PM
MMechura MMechura is offline
MMechura is starting off with a positive reputation.
2002 F-250 6.8L V-10 165K
I'm a DIYer with a lot of fundamental, electrical and mechanical knowledge and ability. I'll be relying on y'all for specifics. I'll chime in when possible, but mostly I'm going to lurk and pick all your brains and expertise. Thanks in advance
Question 1. In the fuse box cavity is 2 plugs 1-24 pin and 1-8pin plug, both male that go into some type of module?? I also don't have high beams, fog lights and cruise control. What is the name of this device and how can I get one?
Question 2. Is there a program or some suggestions for getting more than 11 mpg out of this engine. I have been changing the oil religiously with Moble 1 5W-20 every 4k miles or so since I have owned it. I haven't yet changed the plugs or coil packs but plan to in the near future. There is also an aftermarket cold air intake on the engine needless to say there is tons of power.
Question 3. When I turn on the A/C either standard or MAX the blower fluctuates from the dash to the defroster, it seems to cycle. Is this normal, or is there an issue that I need to address?
Old 08-15-2014, 09:59 PM
Army RET's Avatar
Army RET Army RET is offline
Army RET has a good reputation on FTE.Army RET has a good reputation on FTE.Army RET has a good reputation on FTE.
I can't address the mechanical questions but I can offer advice on the MPG side. Properly inflate your tires and replace the air filter/plugs as necessary; then drive like your grandma (or me).
My 02 F250 V10 182K has a current average is 12.7 mpg.
Old 08-15-2014, 11:16 PM
Yahiko's Avatar
Yahiko Yahiko is online now
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
With the air blowing from the defrosters. That is usually a vacuum
leak in the ESOF 4X4 hub system. Start by looking down near the
back sides of both hubs. You should find a line that comes from a
nipple on the steering knuckle. Trace that back up. You can then use
a hand vacuum pump to check where the lines are leaking.
Sean
Old 08-16-2014, 11:12 AM
3 Questions
Could the module be the GEM module or some keyless entry antenna module?
Old 08-17-2014, 09:56 AM
seville009 seville009 is online now
seville009 is starting off with a positive reputation.
I've got a 2006 5.4l that I would love to get 11 mpg out of; average 8.5 mpg according to the display. Get about 6 mpg when I'm plowing.
Installed a tuner a month or so ago and the average mpg is about 9.8 now, so you could always try that.
Old 08-18-2014, 08:36 AM
update, bump
There is no missing module, it turns out that the plugs that I was referring to were to an aftermarket alarm system, which I removed all the wire to over this past weekend. I still do not have cruise control, I think that may be due to a bad clock spring. Any other ideas? I'm open to suggestions. I still do not have high beams as well even though the high beam indicator comes on at the dashboard. The headlights are aftermarket and I think there may be a wiring issue up front.
EOT not reading right andy's2000 1999 - 2003 7.3L Power Stroke Diesel 26 11-06-2016 09:42 PM
My TO DO list madMatador78 1994.5 - 1997 7.3L Power Stroke Diesel 206 05-06-2015 12:06 PM
P1316 Misfire with Black Smoke on 2002 with New Injectors, Gaskets, & UVCHs NorthernWild 1999 - 2003 7.3L Power Stroke Diesel 18 08-19-2014 02:05 AM
Reassembling Door Hinges ct50f1 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 08-18-2014 10:00 PM
Help confirm glow plug issue santacruzf250 1999 - 2003 7.3L Power Stroke Diesel 3 04-29-2012 11:01 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
