Neutral Safety Switch? 79f150 need help!!!!
Old 08-15-2014, 06:26 PM
ford4her's Avatar
ford4her
ford4her is offline
Arrow Neutral Safety Switch? 79f150 need help!!!!
Please read my earlier post, I really need to fix this problem asap as my truck is my only vehicle. Any advice or info would be greatly appreciated.. Thank You !
Old 08-15-2014, 06:58 PM
fuzzybob's Avatar
fuzzybob
fuzzybob is offline
fordforher,
Sorry I can't help but.... Have you tried a search of the forum for neu/saf/swi ? It should bring up a bunch of threads with the same probs. Good luck.
Old 08-15-2014, 07:37 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Here it is: https://www.ford-trucks.com/forums/1...g-problem.html
To the OP, ya might just wanna bump your original thread instead of starting a new thread which requires us to hunt for the original. Dig? Thanks... it helps us and you stay on track.
...With the engine off, wheels chocked, and transmission selector in neutral, loosen the neutral safety switch at the transmission and with a straightened paperclip, insert the paper clip into the alignment hole. Tighthen the neutral safety switch and remove the paper clip.
Put the transmission selector in "Park" and test. Post your result.
For good measure, clean the battery posts and clean and tighten both ends of the battery cables. Post your result.
Old 08-15-2014, 08:26 PM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
Already replied in the OP's original post.
EDIT: Added my reply to the OP's other, original thread:
More than likely you need to adjust your NSS (neutral start switch).
On the '79 model it should be on the side of the transmission.
Put the transmission in neutral, loosen the two retainer screws and insert the drill (or paper clip, etc.). Once the drill bit goes all the way in, tighten the screws.
While you're under there, look for wear in the linkage, especially the little stud that attaches the shift rod to the shift arm on the trans.
<fieldset class="fieldset"> <legend>Attached Images</legend>
</fieldset>
Old 08-16-2014, 02:15 AM
HIO Silver's Avatar
HIO Silver
'Replied again to reiterate. Seems as though the OP doesn't like to follow up... at least not yet which is odd given the apparent immediacy.
Old 08-16-2014, 07:21 PM
ford4her's Avatar
ford4her
ford4her is offline
Sorry for taking so long to reply. I will be doing the NSS paperclip test and will post my results right after. Thank you for taking the time to respond to my post .
Old 08-17-2014, 07:52 PM
ford4her's Avatar
ford4her
ford4her is offline
Did what you advised and when Bob (my bf ) went to loosen the retaining bolts they were very loose already . Did the paperclip into the hole and followed the rest of the instructions . Truck didn't start . He's going through each step again to make sure he did it correctly the first time . I will post results after .
Old 08-17-2014, 08:06 PM
Scoop531's Avatar
Scoop531
Scoop531 is offline
Just by pass it
It's not the safest way cause it will start in any gear but I have done it in the past in a pinch
Old 08-17-2014, 08:07 PM
mikeo0o0o0's Avatar
mikeo0o0o0
If you get into a bind, unplug the NSS and jumper the two red w/ black trace wires. This will bypass the NSS.
I don't recommend doing that, but it will get you out of a bind.
Old 08-17-2014, 08:28 PM
ford4her's Avatar
ford4her
ford4her is offline
It's still dead .. The only sign of life is the red fasten belts warning light. This sucks ! I was just thinking recently " Truck is running great, been a long time since it's acted up" and then WHAM I jinxed myself !!!
Old 08-17-2014, 08:36 PM
JWC 3's Avatar
JWC 3
JWC 3 is online now
With the key on , can you jump the solenoid and start it ?
Old 08-17-2014, 08:37 PM
ford4her's Avatar
ford4her
ford4her is offline
Unhappy
Is there anything else that could be causing it to do this ?????
Old 08-17-2014, 08:39 PM
ford4her's Avatar
ford4her
ford4her is offline
I'll try and let you know right after
Old 08-17-2014, 08:53 PM
ford4her's Avatar
ford4her
ford4her is offline
Yes it started . I let it run for a few minutes and turned it off to see if it would start with the key only, and it did !!!?
Old 08-17-2014, 08:54 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Hold the key in the "start" position. Slowly pull the gear shift from park to drive. You're checking to see if the truck wants to start with the gearshift in any position. This checks for excess wear in the linkage.
If it doesn't show any signs of trying to turn over, then do what JWC 3 suggested. Jump the starter solenoid and let us know what happens.
Quick Reply: Neutral Safety Switch? 79f150 need help!!!!
