Fuel sender/pump question
Old 08-15-2014, 04:55 PM
walt1968's Avatar
walt1968
walt1968 is offline
I omitted my rear tank on my 96 f250 7.3 due to it leaking some time ago. I ended up just now replacing both tanks. I had to buy the fuel sender for the back, ouch!!! I could have sworn the front sender had a pump attached. I received the rear sender and it has no pump. I know it has a pump on the motor. Am I dreaming about the front tank having a pump? The new sender i received for the back tank definitely doesn't have one. Please tell me it doesn't need one so I can quit worrying!! Part number I got listed was F6TZ9275DA, but on the part itself it was listed F6TZ9275B
Old 08-15-2014, 05:07 PM
walt1968's Avatar
walt1968
walt1968 is offline
Think I got my answer only 2-3 threads down, just 1 pump......If anyone will confirm I sure would appreciate it...sorry for the same question.
Old 08-15-2014, 08:59 PM
farmert's Avatar
farmert
farmert is offline
There are NO in tank pumps on these trucks with a diesel engine. Only the mechinical pump on the engine unless it has been converted to electric pump delivery, then the pump is usually located in the frame rail.
Rudiak
6.4L Power Stroke Diesel
04-17-2018 03:45 PM
fmr9
12-01-2009 08:35 AM
squaredancer
08-14-2006 12:11 PM
moose94
07-19-2004 12:18 PM
Quick Reply: Fuel sender/pump question
