Replaced rear diff and transfer case fluid - Ford Truck Enthusiasts Forums
Old 08-15-2014, 05:14 PM
Liquid_force Liquid_force is offline
Liquid_force is starting off with a positive reputation.
Basically since I've been driving this (bought with 136k, now 168k) I've had the rear end "hum" -- sounds like off-road tires.
I don't know if it's gotten worse over the past few months, or it just seems louder because it bugs me every single mile.
Anyway -- at this mileage I thought it would be wise to replace the fluid. It didn't look good. It had a metallic shimmer to it and was a lot darker than I would liked to have seen.
I also noticed 75-90 stamped on the cover.
I added the 75-140 synthetic and a bottle of champion LSD modifier (I wanted motorcraft, but that's what Oreilly had).
I hoped the new fluid might reduce the noise that drives me crazy, but honestly didn't expect much change. I was happy to find that it's maybe 50% quieter. Quiet enough that I think I might even be able to forget it's there with the fam in the car.
Old 08-15-2014, 07:22 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
I have a 2002 EXP and it had the noise from 30K miles onward. I changed the oil a couple times and added the friction modifier even tho it has no LS unit. That did seem to help 50% as you said. I drove it 120K miles that way. I finally tore it apart 3 months ago and replaced all the bearings. The pinion BEARING was burnt and excessive clearance. Many say it is gear noise and I was agreeing with that until I did the bearings. I think the factory got the bearings too tight and cause the problem. I have the same gears now, new bearings, and NO NOISE.
How should I clean out my rear differential? ExPACamper 1999 - 2003 7.3L Power Stroke Diesel 58 02-23-2016 11:11 PM
'05 F150 Torque Converter vibration? 40-55mph rumblefish73 2004 - 2008 F150 20 07-28-2015 03:22 PM
Oreilly's global multi vehicle ATF jp45601 6.0L Power Stroke Diesel 24 06-30-2012 08:20 AM
Putting an LSD on an 88 Ranger 2wd 86bg Ranger & B-Series 41 09-09-2008 05:25 AM
Corroded HFCM drain plug Black1 6.0L Power Stroke Diesel 16 05-16-2007 11:08 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
