Sponsored by: Halo Lifts
Ecoboost is having the same induction issues
Old 01-12-2015, 07:15 PM
americansteel's Avatar
americansteel
americansteel is offline
Originally Posted by Tom
In reality you have no idea what you're talking about.
Oh yes I have no clue what I wrote here. I just pulled that information out of my ***! Owner of a 2011 Eco turd does not use egr.
Oh I almost forgot. you mad bro?
  #47
Old 01-12-2015, 07:23 PM
Tom's Avatar
Tom
Tom is online now
I'm aware that they don't use EGR, but the VCT is used by lots of manufacturers to improve power throughout the RPM range. You can compare the output of nearly every Ford engine before and after receiving Ti-VCT and you'll notice substantial power gains in all cases.
  #48
Old 01-12-2015, 07:37 PM
americansteel
All new ford engines except 6.2l utilize tivct only engines with 4cam shafts use this set up. I can not compare a 3.5 a 5.0 or any other ford engine with tivct because ford does not have any engines based on the same head stroke and bore design before the current offerings What engine do you want to compare to a 5.0 4v? Ford has nothing to compare it to!
Bud I have built many 5.0 coyote motors for my customers and always lock out vct same power the entire rpm band. No changes. A 4.6big bore 5.0 with similar cam grinds pushes 9 more HP than a factory 5.0 coyote and some emissions. I locked my vct in my Eco turd no changes. I have seen many cars on the dyno push the same numbers with vct lock out as with it on.
  #49
Old 01-12-2015, 08:05 PM
Tom's Avatar
Tom
Tom is online now
Not dragging this thread any further off topic.
  #50
Old 01-12-2015, 08:20 PM
americansteel
Because you have nothing to argue with you know nothing of real world performance or what these factory offering a actually offer. Yes dont drag this off subject any longer you'll just be proven wrong again and again. Tivct does not do anything in power production.
  #51
Old 01-13-2015, 05:27 AM
redford's Avatar
redford
redford is offline
Received 1,561 Likes on 909 Posts
VCT (or in the case of multiple cams, tiVCT) does in fact alter the production of power.
Per Comp Cams:
Advancing the cam timing builds more low end torque
Retarding cam timing builds high end power.
COMP Cams® - Sorry...
Variable timing takes advantage of both of these phenomenoms by advancing the cam timing at low RPMs and retarding the timing at higher RPMs.
  #52
Old 01-13-2015, 06:13 AM
tseekins's Avatar
tseekins
tseekins is offline
Received 1,221 Likes on 803 Posts
Back on topic please. I'm not sure what TiVCT has to do with the alleged 3.5L induction issues.
  #53
Old 03-22-2015, 02:46 PM
brokenleg's Avatar
brokenleg
brokenleg is offline
Originally Posted by YoGeorge
I am talking about my concern for the EB direct injection engines and have done so because I have concern about the EB direct injection engines. I am concerned that Ford has not engineered in any means to keep the back of intake valves clean. Their track record with cylinder head design has not been great.
I have been on Internet forums for 18 years, on FTE for 8 years, and have a very good record here on the FTE. I always do my best to help people here and believe I have done so over the years--perhaps you should check my feedback ratings or my post count which I believe are not characteristic of a troll. I am most often on the van forum because that's what I own now.
This is a *discussion* forum and that, sir, does not mean that everyone has to be a total fanboy with no skepticism. There is good and bad in all machines. I love Ford trucks and chose a 1978 F100 as my first brand new vehicle in 1978. I have had my E150 since 2003 and have had many other Fords along the way and have recommended them to friends. I hope to have other Fords in my future.
Respectfully,
George
1carguy
2015 - 2020 F150
18
10-01-2017 12:43 AM
TomBrooklyn2
2004 - 2008 F150
04-04-2015 08:55 AM
Xenthrax
30
05-10-2012 12:35 PM
vze2sgxa
1997-2006 Expedition & Navigator
22
11-13-2011 06:06 PM
mfp4073
1983 - 2012 Ranger & B-Series
06-01-2008 01:58 PM
Quick Reply: Ecoboost is having the same induction issues
