Stinky is driving me crazy! - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 08-17-2014, 01:09 AM
retiredsparky retiredsparky is offline
retiredsparky has a very good reputation on FTE.retiredsparky has a very good reputation on FTE.retiredsparky has a very good reputation on FTE.retiredsparky has a very good reputation on FTE.
Rich, one trick that you have probably used on occasion is to spray a cold blast of freon, or other gas on suspected components to see if there is a change. I suppose butane is probably not a good choice for around the hot engine, but my point is to confirm that the IDM, the air intake temp sensor, the mass air sensor, etc are not being affected by the heat. Sometimes as you know, electronic devices can get all wacky when too much heat is involved, even though they are replaced. At this point, you cannot really rule out anything, because sometimes the gremlins are and have been hiding in plain sight. AE certainly rules out certain of these issues, are there any items that are not properly vetted by AE which could be suspect? The suggestion about the fuel fittings is a good one, those choke points make no sense! I feel for you-it can get very frustrating.
  #32
Old 08-17-2014, 06:16 AM
Tugly's Avatar
Tugly Tugly is offline
I'm a cautionary tale.
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
I use inverted canned air for a freeze spray. It's not hard to conduct all these tests, it's just very hard to get Stinky to fail when I have the time to do something about it. I have some hot weather coming up soon and I can drive with the A/C on my way home - this almost assures the issue will pop up.
  #33
Old 09-14-2014, 07:54 PM
white Buffalo's Avatar
white Buffalo white Buffalo is offline
white Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud of
any luck with the new fuel fittings?
  #34
Old 09-14-2014, 10:55 PM
Tugly's Avatar
I took one look at where those go, and decided I need some more tools. I have drive vibration issues, air-in-fuel issues, a bench full of goodies to install on Stinky... but no residual patience or time.
It may take a week or two to get all my giveacrap rounded up and back in line - this two-year battle is taking its toll on me.
  #35
Old 09-15-2014, 06:33 AM
I hear ya and know that "back aching gear up the motivation to work in the cramped spaces and scar up my hand again" feeling.
Especially when it's freakin cold outside!
  #36
Old 09-15-2014, 06:41 AM
Tugly's Avatar
Quote:
Originally Posted by white Buffalo View Post
...Especially when it's freakin cold outside!
This is my motivation to get on it sooner, rather than later.
Aerating Oil williameub 1994.5 - 1997 7.3L Power Stroke Diesel 8 02-04-2016 10:47 PM
How far will I take Stinky? Tugly 1999 - 2003 7.3L Power Stroke Diesel 53 10-23-2015 12:42 AM
Talk about an obscure problem.... Tugly 1999 - 2003 7.3L Power Stroke Diesel 18 09-09-2015 03:15 PM
Cackle not just air in fuel? Tugly 1999 - 2003 7.3L Power Stroke Diesel 103 02-16-2014 08:16 AM
e99 SD #8 injector failing CCT lindstromjd 1999 - 2003 7.3L Power Stroke Diesel 12 12-16-2013 09:29 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
