a/c compressor won't kick on
Old 08-18-2014, 11:22 PM
cjdmcgarry's Avatar
cjdmcgarry
cjdmcgarry is offline
I've been troubleshooting the a/c on my 1991 F250 XLT Lariat 4x2 for a few days now. The blower is working, but is not pushing any air through the vents most likely due to a clogged evaporator (its covered in dirt and may be a little damaged so its not allowing air to pass through). Additionally the compressor clutch is not engaging. I read the wires going to the compressor and am not getting any voltage. I tried jumping the accumulator to see if it was a low charge keeping the compressor from coming on and had no luck with the power issue. This leads me to believe that the a/c switch on the console isn't engaging to send power to the system. Any ideas?
Old 08-19-2014, 10:12 AM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
You already ruled out the accumulator, so yes, focus on the console and the compressor wiring itself. Replace the evaporator too.
Dumb question: Did you check any related fuses?.
tps93ranger
1983 - 2012 Ranger & B-Series
11-17-2008 10:50 PM
fordman1090
Offroad & 4x4
04-20-2008 12:04 AM
conger
1999 to 2016 Super Duty
03-19-2007 04:54 PM
ubermich
07-02-2004 03:29 PM
fcarruth
1978 - 1996 Big Bronco
07-19-2003 01:12 AM
Quick Reply: a/c compressor won't kick on
