TTB Swap - What are my options? - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 08-18-2014, 11:23 PM
Ace_of_Spades Ace_of_Spades is offline
Ace_of_Spades is starting off with a positive reputation.
I should also add that the truck sags on the passengers side when driving down the road which is also a possible sign of weak leafs, right? I did not think about swapping the leafs out to coils, and it sounds like it would be a cheaper fix. That or add another leaf? And I think the only reason I haven't taken my truck off-road (other than I've just never went exploring that much with it) is that it has consistently gotten worse over the years.
I can see how people might like this suspension and that it was popular for so many years in production, but for everyday general use, it sucks. As it has aged just like so many others, it sags which makes for an uncomfortable ride. It has never been the pie-in-the-sky ride and leaves me more than frustrated than anything.
  #47
Old 08-19-2014, 04:44 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Swapping from leafs to coils is a MAJOR undertaking and YOU will be making one off pieces to do so
  #48
Old 08-19-2014, 11:45 AM
Nothing Special's Avatar
Nothing Special Nothing Special is online now
Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.
In general, if you aren't happy with your stock leaf TTB suspension, the easiest / cheapest fix is to repair what you have, make sure everything is as good as new.
It sounds like you've already done this and "as good as new" isn't good enough for you. The only tried and proven easy fix from there that I'm aware of is a solid axle swap.
As Brad said, swapping to coils would be a custom fab job. Great opportunity for improvements, as long as you're capable of doing it (I don't know that I would be). But not what most would call cheap or easy.
Adding a spring leaf might keep you from bottoming, but the spring rate is pretty stiff already, so no guarantee it will be acceptable with another leaf.
Just getting new replacement springs might be an option. If they are sagging that might be needed to get to "good as new".
I've never looked into lift kits for an F-250 TTB. There might be something out there that gives a little more wheel travel, so that might be worth a little research.
It really comes down to the fact that it's a marginal system to start with. a few people like it, most of us can tolerate it, and a few need to upgrade. If you're in that third group a SAS is probably your best bet.
1951 F-5, F-6 rear diff, front wheel upgrade options? preppypyro 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 06-20-2016 11:24 AM
Broken brake line, options? TheSterling 1973 - 1979 F-100 & Larger F-Series Trucks 18 04-01-2016 05:17 PM
48 f6 axle swap? fisherman_chuck 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 01-05-2015 08:19 PM
Rear end options hillcountryflt 1967 - 1972 F-100 & Larger F-Series Trucks 78 09-29-2014 04:11 PM
2010 Excursion Conversion has started need HELP chops3131 Excursion - King of SUVs 12 11-14-2013 09:04 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
