Newb with lots of Q's and pics :)
Picked up this project 3/4 finished. I've had many projects, but mostly subarus and volkswagens. I couldn't resist the rat rod look, but am totally clueless on the classic truck scene.
The good:
Interior is finished and very clean
PO converted to a brand new c4 tranny
Brand new (rebuilt) 5.0 with roller cam (from T-bird I believe)
Lots of goodies included
Suspension, brakes, undercarriage, rear end all redone
The not so good:
- Paint is pretty rough
- I have no idea what kit was used for the serpentine conversion, I'd like to have power steering, but no clue what my options are here.
- No baffles drilled in the valve covers??
- Need to figure out a different thermostat housing, the existing one gets in the way of the alternator brace. Do they make a rotated one, or do I have to get creative??
Wonder if you could give me some tips on what to look for. I know I need to figure out a dipstick. It needs wiring -I believe he has a high torque starter. Need to figure out power steering, and various odds and ends.
A few Pics:
The good:
The not so good:
A few Pics:
if i click on the image and go to your google+ site i can see them but not here.....
Good looking truck, for questions about the engine i think you would have better luck here:Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) - Ford Truck Enthusiasts Forums but i am sure people here will have some ideas too.
The valve covers are aftermarket for sure, going to be interesting getting 5 quarts down the dipstick tube for an oil change, unless you have another plan for the valve covers.
The paint i really like that burnt red color looks cool.
Tadaa..............got them here for you.
Those valve covers look like the cheap chinese knock offs. They come without holes, you need to hole saw some in and put a breather in them. Don't think the engine will like being completely plugged off!
Need a thermostat housing from a 1980's Fox body mustang. They shoot straight up if I recall correctly. Might have to ditch that GM distributer though (ugh, why did anyone come up with that monstrosity for a FORD?). Not bad for a chevy when it's in the back and no one can see it. Up front of a Ford, it's rediculous looking and larger/taller then the carb.
The serpentine set up is just an alternator(in stock Vbelt location) and a water pump pulley. Something not right, as the water pump pulley looks like reverse rotation(no ribs). Better confirm before you over heat it. Besides something aftermarket(ie: expensive), why not look at brackets from a 1980's pickup? That would mount the powersteering for you. Might not look fancy but would work. They bolt on the front of the head/waterpump.
Thanks for the help with pics and advice! BTW, how did you get the pics to work?
I thought as much on the valve covers - not too worried about cutting holes.
The previous owner was an interior guy - hence the nice interior. Not sure what he had in mind for much of the custom bits. Looks like I need to take a trip to the junkyard and source some parts.
So freightrain, if I smell what you're laying down, I have the wrong water pump for a serpentine setup?
No clue what was intended with the distributor...
I went to your google site, right click on picture, hit properties. Copy the link in the little box that pops up and pasted it to here using the "picture" icon. Presto!!
Those valve covers are nice, as they are a clean piece. Do with what you want then.
Belt situation scares me, so you need to confirm what he got started. Most NON ribbed pulleys were for reverse rotation pumps(the belt ran over it on the top side== no ribs on pulley). Need to confirm what water pump is there. Std or reverse rotation then build from there. Even if you have to get new one once you find parts to mount pump.
I can get you a shot of my '89 truck motor to give you some ideas.
I hate those DUI type chevy distributors. Plain old stock version is better, but just my opinion.
I'd start over on the belt system. Just go get the whole set up from a junkyard car. Get the water pump too because they run backwards. It will save you frustration in the long run. Get the s3 alternator while your at it, best alternator Ford ever made IMO and easy to wire in.
Personally, I'd ditch the cheesy valve covers and get a set with the proper filler/pcv holes.
Very often we have to recheck and re-do a lot of the work previous owners did. Either because it wasn't done right or not to our taste. Nice truck, good luck with it.
So I gathered a little more detail from the previous owner. The drivetrain came from a 1993 T-bird. It has a roller cam and was rebuilt and the heads were refreshed. The summit racing fan required a new pully on the water pump - no grooves. So I should be okay?... yay, nay?
Could I just go and find another T-bird or stang and swipe the PS pump and bracket? Heck, I'm tempted to go get an EFI setup while I'm at it.
$.02
The mechanical fan is too far away from the radiator to do any good. It'll be spinning there robbing the engine of HP. 'Might oughtta think about a longer fan spacer and fan shroud or going electric.
Nice project.. I dig the patina, white walls, and dog dish hub caps... and a shortbed to boot.
