issues getting my 460 running - Ford Truck Enthusiasts Forums
Old 08-15-2014, 08:30 AM
gregmorton588 gregmorton588 is offline
gregmorton588 is starting off with a positive reputation.
I am having problems getting my 460 going. I bought the truck from original owner after it had sat for about five years. I put a clutch in it and it was running good for about an hour then died and wouldn't start back. I have replaced all relays, distributor, button. I am getting fire and wasn't getting fuel but fixed that problem although I still don't think I have enough pressure but I just figured out the injectors are not getting fire. At first when it happened it would start with starting fluid but a few people have told me to get a new computer need some advice before I go buy that. Thanks
Old 08-15-2014, 09:10 AM
jas88's Avatar
jas88 jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
What did you do to "fix" the no-fuel problem?
Old 08-15-2014, 09:18 AM
Quote:
Fuel tank switch was bad got a new one the old one wasn't selecting a tank so wasn't licking the fuel pumps on
Old 08-18-2014, 08:26 AM
jas88's Avatar
Have you checked the fuel pressure at the rail with the key on?
1992 f250 460 efi wont start. ollisdadda 1987 - 1996 F150 & Larger F-Series Trucks 10 06-02-2016 06:58 PM
460 the king of ford engines ironman1977 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 57 04-19-2016 03:47 PM
'77 F250 w/ 460 won't start after driving DonovanF250 1973 - 1979 F-100 & Larger F-Series Trucks 27 03-03-2015 08:51 PM
1990 460 weird idle and back firing 460jared96 1987 - 1996 F150 & Larger F-Series Trucks 4 10-11-2014 10:26 PM
firing order ky94f250 1987 - 1996 F150 & Larger F-Series Trucks 14 05-22-2014 10:32 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
