Vibration video around 70 mph. - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 08-14-2014, 11:21 PM
DanielT28's Avatar
DanielT28 DanielT28 is offline
DanielT28 is starting off with a positive reputation.
Vibrates bad around 70. I've had tires re balanced. Carrier replaced and shim. And other things. Anyway here's the link.
You can see the phone cord bouncing like a Jump rope.
Old 08-14-2014, 11:36 PM
DanielT28's Avatar
Sorry bout the crap quality
Old 08-15-2014, 02:05 AM
DanielT28's Avatar
I just went on a 60 mile drive. Shakes and vibrates after 65mph. And every once in a while I'll get a clunking noise making a sharp left turn. Seems like hubs may not be released right or something. I have manual hubs. I guess I might just have to check every single bolt and connection on the front end and go from there
Old 08-15-2014, 06:03 AM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Check your tie rods, ujoints, hubs, etc. I can't tell from the video, only way to find it is dig in. Good luck.
Old 08-15-2014, 10:01 AM
DanielT28's Avatar
Ya thanks a lot. Will definitely do.
Thing that sucks is that front u joints on driveline and axle are brand new with about 2000 miles. Hubs are only a year old. And the tie rods are moog and are literally a year old also. Anyway I'll figure it out sometime. When I do I'll let you guys know
Old 08-15-2014, 10:15 AM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
Do you feel this vibration more in the steering wheel or in the floorboard? This is a lifter D60 correct? How was your lift achieved?
What kind of shape are the rubber bushings in the track bar in?
Old 08-15-2014, 11:45 AM
DanielT28's Avatar
Yeah it's a d60. It has like 3-4" lift springs in front. Blocks In rear. I was getting a lot of axle wrap or vibration starting off from stop lights and stuff then I replaced and shimmed the carrier 3/4" and most of that is gone now. But it's still got this vibration past 65 that makes me not even want to drive it on the highway.
I'm taking it back to les schwab tomorrow. And they're gonna completely look it over I guess. I might make them throw new tires on it.
One thing I was thinking was I could put my old 35s back on and see if it also vibrates.
These are new toyo 38s. So if it don't vibrate with those it's gotta be the tires ?
Track bar bushings are less then a year old.
Stumped because I cannot figure this out!! It's driving me nuts. I just want my truck to run smooth for once. It makes me appreciate the times it is running right that's for sure
Old 08-15-2014, 11:50 AM
DanielT28's Avatar
Track bar bushings less then a year old replaced by me.
Shackle bushings less then a year old by me
Front leaf bushings less then a year by me
Tie rods less then a year or close to a year by me (les schwab aligned)
Toyo MTS with only about 2500 miles.
New front drive shaft u joints about 2 years old.
New front axle u joints and axle seals less then 4 months old (mechanic said new u joints were "heavy duty" )
New manual hubs less then 2 years by me.
New power steering pump by me 1 year old.
New dual steering stabilizers about 2 months old.
New rebuilt steering column less then 2 months old.
Pretty much only thing I haven't replaced is steering box.
Old 08-15-2014, 11:52 AM
DanielT28's Avatar
I feel it more so in the floorboard. But some in steering. Seems to have gotten worse after my first tire rotation. (Put the RR on LF. And LR on RF )
Old 08-15-2014, 03:05 PM
DanielT28's Avatar
Guess there's a lot of things it could be. My list of things to check
-drive shaft straight (left and right wise)
-do I need to rotate 180 degrees ? Or is that even possible.
-tires balanced again
-make sure manual hubs are unlocked
Old 08-16-2014, 10:38 AM
tjc transport's Avatar
tjc transport tjc transport is online now
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
i put my money on the rear universal being bad.
Old 08-16-2014, 11:11 AM
DanielT28's Avatar
We'll I'll keep that in mind. I'm going to throw my old 35s on today and see what kind of results I get. I'll keep you guys updated
Old 08-16-2014, 07:51 PM
Quote:
That's probably it if you have stacked blocks like your other post mentions.
Old 08-17-2014, 11:44 PM
DanielT28's Avatar
Put 35s on. 90% vibration gone. Gonna go to les Schwab. Have them check balance and do it right. Or demand to give me a new set.
Keep you updated
Old 08-18-2014, 06:40 PM
DanielT28's Avatar
Sitting at les Schwab right now. Guy went on a ride with me on the freeway and immediately said "holy crap. There's definitely something wrong. " lol. Said they'd give me a new set if it came down to it
2015 - 2016 f150 rear block removal video Lazyj7 2015+ F150 2 06-24-2016 04:35 PM
Vans of days gone by, Where the heck was I? tx2sturgis 1968-2013 Full Size Vans 10 10-29-2014 06:24 AM
Memorial Day--Why it matters. Doc 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 05-25-2014 09:41 AM
7.3 ISSUES wiley79 1999 - 2003 7.3L Power Stroke Diesel 15 05-15-2014 03:19 AM
Fuel Rate/Surge During Regen [VIDEO] doczenith1 6.7L Power Stroke Diesel 0 04-29-2014 11:42 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
