Vibration video around 70 mph. - Page 2 - Ford Truck Enthusiasts Forums
Old 08-18-2014, 07:30 PM
DanielT28's Avatar
DanielT28 DanielT28 is offline
DanielT28 is starting off with a positive reputation.
image_zps690f935f.jpg Photo by danielt28 | Photobucket
This is what I have for blocks. That's why I want to do shackle reverse.
Old 08-18-2014, 09:15 PM
DanielT28's Avatar
We'll the guy at schwabs made the call for new rims because where the other ones mount up to the Lugnuts seems to have been smashed in by the Lugnuts being put on to hard. So we went and put the front two on and went on a drive and it improved the vibration by 80%. Then we put on the rear 2 for a complete set of 4 and went on a drive. And it was back down to about 40% better.
We're ordering new tires to put on and see if it does this still. If it does i'm going to guess that the u joints are bad in the rear driveline. 10" wide wheels are very nice tho.
Tires will be here Thursday. In the. Meantime I could tried to put on new U joints and see if that eliminates it but should I wait for the new tires?
Old 08-19-2014, 06:43 AM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
Is there any slop in the u-joints? Does your truck have the two piece rear drive shaft and if so, have you installed any spacers in the carrier bearing? I know the vibration didn't start with the lift, but it could be contributing to premature u-joint wear.
Old 08-19-2014, 07:59 AM
DanielT28's Avatar
Yes I have the crew cab with the 2 piece drive line. I replaced the carrier bearing 2 weeks ago. And while I was at it I shimmed it 3/4 of an inch. ( I have 3" Lift and I read for every 1" lift to shim 3/4". ) this is the 2nd time I've replaced the carrier bearing in 3 years. But 1st time I've shimmed it. And I've never replaced the rear u joints since owning the truck.
Weird thing is with my smaller 315-75s the vibration seemed to be almost completely gone. And with the 385/70s it's there. So idk. I'm pretty stumped
Old 08-19-2014, 08:49 AM
DanielT28's Avatar
Shimming the carrier eliminated most of my hop taking of from stop lights and turning corners after a stop light or sign. But it still vibrates 65 mph and up. Like it has since I got these tires
Old 08-19-2014, 08:53 AM
I guess we will have to wait and see what Schwab comes up with.
Old 08-19-2014, 10:49 AM
DanielT28's Avatar
Yeah. Me too. Keep you all updated
Old 08-19-2014, 04:03 PM
IDMooseMan's Avatar
IDMooseMan IDMooseMan is offline
IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.
Saw this and thought I'd throw in my two cents worth, but it sounds like you're close to a resolution.
I had new tires put on several years ago (not my current set) and at the first tire rotation, developed a pull and wobble when leaving the shop and driving through the parking lot. Drove right back to the shop entrance and explained what was happening. The shop rebalanced the wheels, installed them at the same locations, and the tech joined me on the test drive. Same thing happened with the tech in the passenger seat. Back to the shop entrance, "unrotated" (i.e., put the wheels back in the locations before this happened) the tires and NO MORE PULL OR WOBBLE. Determined it was a tire manufacturing issue. The shop replaced all four tires that same day.
Old 08-19-2014, 05:04 PM
DanielT28's Avatar
Ya. I'm really really hoping that new tires will fix it. It's been a frustrating process and just wanna figure it out
Old 08-19-2014, 05:10 PM
DanielT28's Avatar
And yes this sounds like it's what's happening to mine. They're going to replace out of manufacturers defect for free if ends up being the issue
Old 08-21-2014, 07:14 PM
DanielT28's Avatar
They have now thrown 2 new tires on. Went for a drive and felt great. Gonna go pick it up with all 4 installed. Wish me luck.
Old 08-21-2014, 08:42 PM
OldWoodsDiesel's Avatar
OldWoodsDiesel OldWoodsDiesel is offline
OldWoodsDiesel is gaining momentum as a positive member of FTE.
Good luck!
Thanks for posting - def good to know!
If it does turn out to be the tires, what was the brand?
  #28
Old 08-21-2014, 09:00 PM
DanielT28's Avatar
It was the tires.
385/70-16 TOYO MTS.
They gave me 4 brand newies
  #29
Old 08-22-2014, 05:57 AM
Quote:
Originally Posted by DanielT28 View Post
It was the tires.
385/70-16 TOYO MTS.
And that fixed it completely?
  #30
Old 08-22-2014, 08:55 AM
IDMooseMan's Avatar
Sometimes there is a "problem" during manufacturing that can't be seen. IDK what it is or what happens, but the one and only time I received some bad tires, the shop replaced them with no questions asked. This condition isn't brand specific. The tires I had the problem with were Goodyear. It's just something that happens sometimes. The tire manufacturers are aware this happens. They have been more than willing to replace the tires when it does happen.
2015 - 2016 f150 rear block removal video Lazyj7 2015+ F150 2 06-24-2016 03:35 PM
Vans of days gone by, Where the heck was I? tx2sturgis 1968-2013 Full Size Vans 10 10-29-2014 05:24 AM
Memorial Day--Why it matters. Doc 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 05-25-2014 08:41 AM
Fuel Rate/Surge During Regen [VIDEO] doczenith1 6.7L Power Stroke Diesel 0 04-29-2014 10:42 AM
Slight Miss A/Ox4 1999 - 2003 7.3L Power Stroke Diesel 12 10-07-2013 08:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
