Trans plug leak - Ford Truck Enthusiasts Forums
Trans plug leak
Old 08-14-2014, 06:36 PM
Liquid_force Liquid_force is offline
Liquid_force is starting off with a positive reputation.
Trans plug leak
'03 Aviator
I changed my trans filter and fluid a few weeks ago. Since then I've been getting a few drops of fluid on the floor every day.
Trans is clean, plug is wet.
Was there supposed to be a gasket or o-ring? I don't recall seeing anything.
I thought I'd add a metal gasket and some teflon on the threads.
Good idea? Bad idea? Other ideas?
Old 08-14-2014, 10:03 PM
Mikeman Mikeman is offline
Mikeman is starting off with a positive reputation.
Rock Auto shows two different types of drain plug gasket. A gasket should be all you need. Teflon tape is for tapered pipe threads. I wouldn't use it. You run the chance that some of it will come off and get in the oil pan or the pickup.
Old 08-15-2014, 05:16 PM
Put on a nylon gasket and added 1/2-3/4 qt today.
Will be keeping an eye on the garage floor the next few days.
trans fluid leak (again) Dank Hill 1987 - 1996 F150 & Larger F-Series Trucks 0 02-25-2016 12:07 PM
Trans is leaking no idea where its coming from Deisel-life123 1997 - 2003 F150 11 10-04-2015 10:29 AM
aod leaking fordboy97 1987 - 1996 F150 & Larger F-Series Trucks 3 12-01-2014 09:26 PM
4R70W Leaking help! fordcrzymike 1997 - 2003 F150 1 09-27-2012 12:50 AM
Vent in my 4r100 trans nb1997 Clutch, Transmission, Differential, Axle & Transfer Case 1 12-30-2003 04:28 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
