New to me 1966 F100
Old 08-14-2014, 02:26 PM
PapaMatt's Avatar
PapaMatt
PapaMatt is offline
New to me 1966 F100
Hey all, so I ended up buying a 1966 F100, although I admit to feeling a bit (ok alot) overwhelmed by it now that it is actually sitting in my driveway. She does start right up and run well but so many little things need to be fixed that I don't know where to begin. The gas sending unit is not working properly and the smell of gas in the cab is pretty strong so I am guessing it is both faulty and leaky. Will start there.
Not much to look at right now but frame is sold and there are only a few spots of bad rust to deal with.
Here we go...
Old 08-14-2014, 02:45 PM
daveengelson's Avatar
daveengelson
daveengelson is offline
It's a keeper, wow, suggest keep her on the road while working on making sure she's mechanically sound; meantime, decide whether or not want to consider upgrades. Wow, electronic ign., and power assist brakes, what a find. Looking forward to your input. May want to take some extremely find sand paper, or mild paint remover and see if that's an anodized alum. grille.
Old 08-14-2014, 02:54 PM
gangstakr's Avatar
gangstakr
gangstakr is offline
Congratulations, take care of your fuel issue, new rubber at filler neck, new clamps. Pull out your fuel sending unit, make sure float isn't full of fuel, if so replace it.
Make sure your brakes are up to standard. Get your wiring fixed as needed. Then drive it and enjoy. Work on rust issue as time and money allows.
Work out a plan for doing what you want it to look like and act like. A well thought out plan and a realistic plan is best.
It looks like you have a good foundation for the project.
Don't be foolish and start a complete tear down unless you have the money and the time to dedicate to it.
As you drive it, you'll figure what needs to be addressed and how to resolve the problems, if any.
Enjoy your new toy.
Old 08-14-2014, 03:08 PM
svolpone's Avatar
svolpone
svolpone is offline
You're wrong, it's a beautiful thing to behold. I grabbed one in November (although mine is a 64 and not as nice as yours) and I felt overwhelmed at first. People here helped me get over my fear. Just get a plan and execute it. Think of it as a journey of discovery. I didn't know ANYTHING about this stuff, and now I feel that I at least am not in over my head. Of course, I may be, but I probably don't know it. lol.
Good luck. Seriously, great looking truck.
Old 08-14-2014, 06:40 PM
PapaMatt's Avatar
PapaMatt
PapaMatt is offline
Thanks for the positivity guys, I needed the boost. Definitely will NOT be tearing it down for a complete rebuild. It runs fine and I am just going to go bit by bit checking everything out. I just got overwhelmed with it sitting in the driveway and needed to take a step back and start a list and make some progress.
Old 08-15-2014, 03:47 PM
ddavidv's Avatar
ddavidv
ddavidv is offline
Guaranteed the filler inlet hose is rotten and leaking, which is why you're smelling gas. Cheap and easy fix, but only buy the correct hose...don't try to use 'regular' hose as it won't last. Dennis Carpenter makes the right one, and it's sold by most of the vendors (I like Flashback F100s and Carolina Classics).
Old 08-15-2014, 06:51 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
C1TB-9047-A .. Neoprene Fuel Filler Hose / Reproduced
Available from Carpenter (Concord); Carolina Classics (Durham).
Flashback F100's is located in Reedsville, but AFAIK, only sells used parts.
The original fuel sending unit float is made from two pieces of copper soldered together. Solder breaks down, gas seeps in, float settles to the bottom of the tank.
Carpenter also sells a one piece brass fuel sending unit float that'll never leak for about 5 bucks.
Old 08-15-2014, 07:02 PM
resonateur's Avatar
resonateur
resonateur is offline
Matt:
If your sender float isn't the problem, let me know as I have a couple original senders. Remove the sending unit and put it an ohmmeter from the mounting plat to the lead connector and make sure the ohmmeter reads "up and down" when you raise and lower the float arm. Of course, if the float is full of gas, or has a hole in it, there's an easy fix. I agree, replacing the rubber filler neck should solve your odor problem; at least your fuel odor problem.
Old 08-16-2014, 02:13 AM
700buck65F100's Avatar
700buck65F100
700buck65F100 is offline
Great looking truck, you have a nice solid foundation. Just take it one piece at a time and have fun with it.
Old 08-16-2014, 07:10 AM
shortwide's Avatar
shortwide
shortwide is offline
You have the right approach....drive it while you fix it.
All of the previous advice has been spot on....don't think I can add much too it.
And for it's worth, the fuel gauge in my 66 didn't work when I bought it. I pulled the sender and sure enough, the float was rotten. I replaced it and the gauge works perfectly.
Old 08-16-2014, 07:21 PM
PapaMatt's Avatar
PapaMatt
PapaMatt is offline
Thanks NumberDummy and resonateur for info on the sender, however I am pretty sure the PO put in an aftermarket unit to go with the Sunpro gauge. Reviews on the sending unit are not great. I am going to pull it and see if maybe it was not trimmed properly for the tank. If it is correct and still not working will have to replace.
That brings me to a question of what instrument panel is original in these triucks? I've seen the large circle speedo and the Custom Cab "bar" speedo but a lot of pics online also have the or or two big gauges in middle with two little ones flanking. Assume that's all aftermarket?
Old 08-16-2014, 08:11 PM
NumberDummy
Originally Posted by PapaMatt
That brings me to a question of what instrument panel is original in these trucks?
I've seen the large circle speedo and the Custom Cab "bar" (sweep) speedo but a lot of pics online also have the or or two big gauges in middle with two little ones flanking.
1965/66 F100/250 2WD Custom Cabs & Rangers used a plastic chrome "sweep" speedo instrument cluster bezel. See parts catalog pic.
All other 1961/66's used the round speedo. Custom Cab instrument cluster bezel is chrome steel, Standard Cabs used a painted steel instrument cluster.
The oil (9273) & amp (10850) gauges were optional for both the round and sweep speedo instrument clusters.
Old 08-16-2014, 08:36 PM
daveengelson
They also come in the large speedo w/ 2 smaller size outer gauges, oil pressure and alt.
http://i300.photobucket.com/albums/n...s/IMG_0011.jpg
Old 08-18-2014, 01:34 PM
PapaMatt's Avatar
PapaMatt
PapaMatt is offline
Thanks guys, those were the two clusters I was seeing in the pics. PO screwed some piece of black metal into the opening on top of whatever bezel is back there so will take some of those screws off and see what it looks like back there...
It was raining today so got a chance to check for leaks. There is water all the away around the bottom of the windshield on the inside and kinda pools on the drivers side and runs down to the floor by the door hinges. Pic below. Am I going to have to pull out the windshield and replace all of the seals to fix most likely?
Second and third pic are of misalignment in the driver door. It rubs on the hinge said and a decent gap on the handle side.
pooling water
Also snapped a pic of the misalignment for driver door
Any ideas appreciated!
Old 08-18-2014, 03:51 PM
daveengelson
Suggest start at door post striker plate. Currently shopping for hood hinge that broke on my 65 so I copied the adjustment procedure out of the 65 Ford shop manual, which so happened to include the door adjustment. About as brief instructions on subject as one will find.
http://i300.photobucket.com/albums/n...truck_0001.jpg
Quick Reply: New to me 1966 F100
