1994 f350 color?
1994 f350 color?
ok like the title says i have a 1994 f350 4 door and was wondering what color my truck was i know its, "hunter green?" i believe but what does ford call it and where can i find it at. just washed my truck and saw a little spot of rust on rain gutter and wanna get rid of it and paint over it. thank you in advance
Check the Exterior Paint Color code on the b-pillar sticker. It's typically a two letter code.
Example below: Ext. Pnt YC is Ford color Black
1995 Ford F150 Touch Up Paint - Colors for 1995 Ford F150
I only know what I've read about body work (have not done anything more than sanding on a vehicle's sheetmetal), so don't assume I'm entirely correct:
You have to remove all the rust. From what I've read, you have to go about 2" past rust to really help prevent it from returning (still no guarantees). Ideally you would at least grind it off and cut into the sound metal 2" or more, then weld in new sheet metal, grind smooth, apply body filler and sculpt it to make it seamless. Then, prime and paint.
I'm sure some of these other guys will have advice with more experience.
hotrod351
02-03-2015 11:01 AM
webster52
05-23-2008 09:22 AM
