1950 F3 buying advice - Ford Truck Enthusiasts Forums
Old 08-14-2014, 10:29 AM
WSPanic201 WSPanic201 is offline
WSPanic201 is starting off with a positive reputation.
Hi Everyone,
I am considering buying a 1950 F3 that is about 15 miles from my house. Here are the pictures of the one I am looking at.
The engine is shot though everything else looks pretty good. In my research, the bed appears to be unoriginal (don't know for sure), though that is fine with me because it is perfect for what I will be using it for. I am not necessarily looking for a restore project using all original parts, but I would like to save what I can as I find these old trucks to be really dang cool.
The guy selling it suggested looking for an older truck (60-70's) that is pretty much intact and just swapping out the other trucks engine, transmission, etc into the F3.
So, my questions:
  • The obvious - What are your opinions on a fair price?
  • Has anyone ever converted the rear axle to a dually? (i've searched and couldn't find much, but I am sure it has been done)
  • Any other general advice would be appreciated.
Thanks so much and I look forward to hearing back from everyone!
Old 08-14-2014, 04:24 PM
FortyNiner's Avatar
FortyNiner FortyNiner is offline
FortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to behold
Welcome!
Prices for F3s are an interesting exercise. Couple of questions:
Where in the world are you? Because with the bigger trucks, location matters even more than with F1s.
Are the wheels original? If so, Google 'widow makers' as they are completely unsafe.
Others will chime in - my dirty guess is fair price in current condition would range from $1500 to $4000. Remote location (fewer buyers) and widow makers puts you in the lower end.
DW
Old 08-14-2014, 04:38 PM
Thanks for the response!
I am located in Iowa. As far as I can tell, the wheels are original. I have looked a little into the Widow-maker issue and will obviously need to change out the wheels to make this as safe of a drive as possible. I haven't looked around a whole lot on how to fix that specific issue, which I should probably do.
Thanks again and any other input is appreciated!
Old 08-14-2014, 04:55 PM
truckdog62563's Avatar
truckdog62563 truckdog62563 is offline
truckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud of
First, welcome. Glad to have you in the group.
The truck seems real solid. Your profile says Iowa, but that's a big place. You might add location to your profile in the corner of your posts. The truck most certainly has the 17" widow makers that they all came with. But since you want to make the truck DRW it's not really a hard problem to fix. IIRC an F-350 cab and chassis model (not pickup) DRW axle from 73-75 has the same 34" wide rear frame, along with your trucks 8 x 6.5" bolt pattern. It should bolt right in, but would require driveshaft work. For the front any SRW F-250 wheels up to the 97 HD model will fit. As for the truck's value, I'd base that on the degree of rust and other bodily abuse you find. From your pics it looks solid, and has a complete stake bed (non factory). I think I'd be in the $3000 neighborhood, less if you can do it. Stu
Edit - if you do not do the DRW conversion, you still need to be rid of the widow makers. Since you have 14" rear drums on the stock Timken there are only two straight forward wheel swaps, either tubeless 17.5s or 19.5s that first were available in 1956. If you want to hear more about this please say. Otherwise an axle swap to a 1972 or earlier F-250 Dana 60 will be needed to give you 12" rear brakes. Stu
Edit Edit: before somebody else says it, you could also try to find an F-2 complete Timken or at least the backing plates and drums that are 12" for all years 48-52. Stu
Old 08-14-2014, 09:07 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe Jolly Roger Joe is offline
Just another Joe
Jolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud of
Welcome to FTE!
I waited until Stu responded with answers to your questions, as I don't know about any of them for an F3. I agree it looks like a solid truck in the pics.
I would keep that bed and maybe change the stakes. How wide is the bed? If you're going to DRW it should be about 80" to 82" wide so the rear wheels don't stick out. It looks wide enough in the pics, but you should check.
Here's a drawing with the F4 - F6 dimensions, which are all DRW trucks.
Old 08-16-2014, 11:32 AM
tjdad62's Avatar
tjdad62 tjdad62 is offline
tjdad62 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by WSPanic201 View Post
Hi Everyone,
So, my questions:
A fair price could be just about anything, but I got my 1950 F-3 for $800 here in Colorado. It was an Arizona truck most of its life and I think I got a pretty good deal. Mine had the original bed on it and I went with an F-100 9 inch rear. The original flathead was froze and sitting in the bed along with the transmission. I won't be using it as a heavy hauler...strictly cruising.
Old 08-18-2014, 02:15 PM
Wow! Thanks so much for everyone's input. This seems like a great community and looking forward to being a part of it!
Matt
Old 08-18-2014, 04:54 PM
fordf348's Avatar
fordf348 fordf348 is offline
fordf348 is starting off with a positive reputation.
If you do decide to buy the f3 and get rid of the widow makers, let me know I can use 2 of them if they are relatively rust free
Ed
near Philadelphia
New to the site and looking for my first F100, Pics Inside Andres0286 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 11-13-2015 11:01 PM
1963 Wrongbed images F-ONE 1961 - 1966 F-100 & Larger F-Series Trucks 8 07-12-2015 02:58 PM
52 F8 Truckstell Conversion twin screw harleymsn 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 05-13-2015 05:47 AM
1956 Ford F100 doors 53ford Ford Truck Parts for Sale 1 03-16-2015 10:52 PM
Please Weigh In With Advice on Purchase easongt 1987 - 1996 F150 & Larger F-Series Trucks 90 10-20-2014 09:35 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
