Mig welders, anybody have one of these? - Ford Truck Enthusiasts Forums
Old 08-14-2014, 08:05 AM
Drewski 2's Avatar
Drewski 2 Drewski 2 is offline
Drewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud of
After nearly 28 years, my trusty Linde 225 mig welder has gone belly up. Considering that there is hardly a day goes by that I'm not welding on something, I feel like I've lost a body part.
I've starting looking at new mig welders and Hobart's IronMan 230 and Miller's Millermatic 212 seem to fit what I'm looking for. They are both in approximately the same price range with the Hobart on the cheaper side.
Does anyone have any experience with either of these welders?
Old 08-14-2014, 08:17 AM
clintonvillian clintonvillian is offline
clintonvillian has a very good reputation on FTE.clintonvillian has a very good reputation on FTE.clintonvillian has a very good reputation on FTE.
I just purchased a Hobart 210MVP and it runs well ( I bought it over the 230 due to the 120/230V option). I have experience with both the Miller and Hobarts. The Hobart is made by miller, several of my pieces have Miller stamped on the Hobart machine. The only difference in running the machines is the Miller has a dial in Current setting where as the Hobart has a fixed number of adjustments.
Old 08-14-2014, 08:27 AM
tinman52's Avatar
tinman52 tinman52 is offline
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
I have a Miller 210, which is similar, but probably 6-8 years old now. I did buy it new...
Awesome welder, never a problem. Miller is a quality company, I am still using my 110v Miller mig that I bought in 1985!
I think Hobart is made by Lincoln or Miller. Never used one, so I can't help there.
Old 08-14-2014, 09:33 AM
Rimrock F1's Avatar
Rimrock F1 Rimrock F1 is offline
Rimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud of
I have a Miller 211 and love it. I'm not the greatest welder and this machine makes me look like I am. The dual voltage works for me as there have been occasions when I needed it portable with no 220v near by. Have had no problems with it.
Old 08-14-2014, 12:42 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
Hobart is made by Miller, branding is mostly for distribution channels: Hobart is their direct merchandised/mass marketed line, Miller is their welding supplier line. Except for small details they are clone machines.
These are large HD machines, mostly suited for professional welding shop, they would be way overkill in 90% of home shops. Do you do enough single pass welding of very thick material and/or are a pro welding most of the day every day to need this much machine? Do you have 50A 230V service? If so go for it, you won't be disappointed with either machine.
If I was in the market for a new home shop machine, I would buy the Eastwood 175. It is a high quality industrial grade machine that will handle most anything the hobbyist might need to weld (will weld 5/16 single pass and the same thicknesses the larger machines will with V grinding and multipass) and at 499.00 INCLUDING a nice accessory spool gun is a real bargain IMHO.
Old 08-14-2014, 02:09 PM
truckeemtnfords truckeemtnfords is offline
truckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to behold
I do not have either machine, I currently have two Lincolns. I have used both Miller and Hobart in the past, good machines. If I was to buy a new machine today (and I am thinking of adding to my shop) I would look at the Tweeco machines. They have several sizes and I would look at the 181, dual voltage multi-process machine. Comse with stick stinger and mig gun. You can purchase the the tig package for it and tig steel, all for a fair price.
Old 08-14-2014, 04:09 PM
Drewski 2's Avatar
Just to clarify, I might be welding on a front end loader today and 20 ga sheet metal tomorrow. My old welder, a Linde 225, is a big welder for a home shop, but it has been one of the best investments I've made, paying for itself many times over. I haven't ever had a need for a dual voltage machine or portability. I look to brand names like Miller, Hobart and Lincoln because of easy access to consumables and service if needed.
I appreciate all the responses....still hoping for some hands on experience with one of the two welders I indicated.
Old 08-14-2014, 10:16 PM
Last chance 53 Last chance 53 is offline
Last chance 53 is gaining momentum as a positive member of FTE.Last chance 53 is gaining momentum as a positive member of FTE.
I have a miller 212 and had a 210 in the past. The 212 works great and has done alot of welding. I built my trucks chassis with it and would not have wanted anything smaller. I also weld tractor parts with it. The 212 comes with a 250 amp gun which is very nice. The infinite voltage and wire speed come in handy too.
Old 08-15-2014, 07:25 AM
Drewski 2's Avatar
Quote:
Thanks.....glad to hear from someone that has one. I may have a 212 before this day is over.
Old 08-15-2014, 07:42 PM
bobbytnm's Avatar
bobbytnm bobbytnm is offline
Roast em' if you got 'em
bobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud of
A sad day, the old Lincoln 225's are good machines. I've run my share of wire through them.
I just have a little Millermatic 135 now-a-days. I love it. I hardly ever need to weld on anything over 3/16", when I do, I head over to my buddy's shop and borrow his bigger machines.
I think you'd be happy with the new Miller.
Bobby
welding Leroy Unlisted Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 30 05-20-2016 03:44 AM
Anybody Have a Hobart 210MVP mig welder? dougbrown Garage & Workshop 13 10-04-2012 07:38 AM
Lincoln or Hobart Welder? Gage2502 Garage & Workshop 17 05-14-2012 06:59 PM
Welders, Welders, Welders... FordNFishinLover Garage & Workshop 30 10-08-2010 09:22 PM
Mig Welder Anyone? 4 sale jimbo81587 Paint & Bodywork 1 01-07-2003 12:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
