52 Ford bed extension replacement? - Ford Truck Enthusiasts Forums
Old 08-14-2014, 06:23 AM
52' fordnut 52' fordnut is offline
52' fordnut is starting off with a positive reputation.
Hi,
I recently had my truck bed sandblasted and found out what truly was underneath the paint. Come to find out, the bed extensions that are on the back of the bed (the little piece with one bolt in it for the fender) were rusted through. I found through LMC a set of the extensions for about $12.00 and I am going to get them.
However, how would one go about replacing them? They don't really appear to be welded, but then again they are attached very sturdy. Any help would be appreciated.
Thanks,
Jon Preston
Old 08-14-2014, 09:35 AM
tinman52's Avatar
tinman52 tinman52 is offline
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
They are spot welded on. You will have to drill out the spot welds to remove them, then weld on the new ones.
Looking for original vaccum pump style wiper motor 52' fordnut WTB - Parts & other 6 09-30-2015 08:49 PM
Opinions needed, Fiberglass/Steel Running boards 52' fordnut 1948 - 1956 F1, F100 & Larger F-Series Trucks 27 06-30-2015 12:50 PM
52 Ford F1 tech questions 52' fordnut 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 06-25-2015 01:00 PM
52 Ford F1 Door Panels interior??? 52' fordnut 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 11-19-2014 07:21 AM
52 Ford F1 Hood reattachment 52' fordnut 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 10-19-2014 03:49 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
