starting research Ford E350 exstended
Ok first post so i will be brief with the brief
I am looking to purchase a E350 diesel extended Van in a couple of weeks .
I will be building a 2wd camper with plans to make it 4wd later.
I currently drive a 03 F250 triton 5.4 and love it .nearly a quarter of a mill on the clock and still going strong i do the plugs every 30 thousand use synthetic oil best rig i ever owned
so that's the work truck. i plan on doing some serious traveling down through Latin America so want as reliable as possible i have heard some horror stories about the newer 6.L diesels from Ford so need to get this right the first time i have a budget of about 15 grand maybe more if the right one pops up .
so back to the brief do i go for an older 7.3 engine or are the later diesels as good .This will be a heavy rig once built big fuel load potable water, black ,grey propane and a vw rabbit on a bar for the sight seeing once base camps set up . if there are any previous threads apologies i am not very tec savy
regards Paulanthony
regards Paulanthony
Here on FTE there are several sub-forums for diesel engines, most every type and CID covered by those more in the know of such things. Typically vans in this forum will be gasoline making diesels a bit rare. I'd look further on FTE for the engine type you're anticipating purchasing and explore some of the issues under discussion about them.
I'll leave some info in your User CP's message area about building an E-Series into a combo vehicle as you describe.
HTH
HTH
And the amount of cargo you described is going to require large fuel useage no matter which engine you choose.
With that said I believe a diesel is probably your best bet. Thats a huge load for any engine.
jmmartin
04-01-2011 09:05 PM
NY Signman
12-18-2005 09:27 PM
