AC comes out of defrost vents
Old 08-13-2014, 11:49 PM
snorindad's Avatar
snorindad
snorindad is offline
So when my ac is on it mostly comes out the dash vents but some comes out of the defrost vents. Like 70-30 I guess. If I am not mistaken it is all controlled by vacuum. Any suggestions?
Old 08-13-2014, 11:57 PM
Rellick's Avatar
Rellick
Rellick is offline
You are correct, i would check for vacuum leaks.
The nice thing is, the climate control and hubs are ALL that is vacuum controlled. My F150 had a vacuum leak that made it run like junk, took me months to find.
I hear the hub lines are a common spot for the leaks.
Old 08-14-2014, 08:18 AM
rocco7869's Avatar
rocco7869
rocco7869 is offline
The vacuum canister is on the passenger firewall behind the battery. Thats a good place to start.
Chuck
Old 08-14-2014, 08:20 AM
bthr22's Avatar
bthr22
bthr22 is offline
You could try this little adjustment on the vacuum pump. I have yet to try it on mine. If that doesn't work, the pumps are relatively inexpensive to replace.
This is assuming you don't have a vacuum leak anywhere else.
Old 08-14-2014, 08:22 AM
TxMav's Avatar
TxMav
TxMav is offline
Also, the little valve on the passenger side near the firewall behind the oil fill cap. It's black and a little bigger than a golf ball. The hose fell off of it on my truck and caused the same symptom. Easy fix. Just find the hose and reconnect it to the valve.
Search for this thread, it is helpful too. 'AC blows out Defrost'
This thread: https://www.ford-trucks.com/forums/1...=blows+Defrost
Old 08-15-2014, 04:36 PM
snorindad's Avatar
snorindad
Thanks for the reply's I will try and check this all out over the weekend.
Old 08-16-2014, 07:29 PM
miked_939's Avatar
miked_939
miked_939 is offline
Originally Posted by bthr22
http://youtu.be/6F96gOhTBEI
^definitely check the vacuum pump, there was a tsb for it being inoperative or running continuously. I had to replace mine
Old 08-16-2014, 11:49 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
I have some diagrams if it will help.
AC 1
AC 2 Valve
AC 3 EATC
What I don't have is the 4X4 diagram. I'll try and get that up for you later.
Sean
EDIT : Got the Service info from the workbook for you. One nice PDF for you.
Old 08-17-2014, 07:00 AM
bigredtruckmi's Avatar
bigredtruckmi
bigredtruckmi is offline
Would this diagram work for a 04?
Old 08-17-2014, 07:20 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
Some things will be the same. But not all.
I no longer have a 2003~2004 to look at.
Sean
Old 05-24-2020, 06:10 AM
FordTruckNoob's Avatar
FordTruckNoob
FordTruckNoob is online now
Identifies as He/Him/Noob
Received 2,915 Likes on 1,930 Posts
Here, run through these tests methodically.
Old 05-24-2020, 09:20 AM
bigredtruckmi
Found my problem was a bad alternator. Wouldn’t keep ac clutch engaged.
Old 05-24-2020, 10:39 AM
SmackDaddy's Avatar
SmackDaddy
SmackDaddy is offline
Old thread back from the dead but good information!
If your vacuum lines have a leak anywhere or your truck has ESOF 4wd and the hub seal or seals are compromised you will also not build vacuum and the hubs won’t engage and the vents will default to the defrost mode. I deleted my vacuum lines to the hubs and installed manual Warn hubs.
Old 04-23-2023, 10:46 AM
bigtexan99's Avatar
bigtexan99
bigtexan99 is offline
The same problem of AC only coming out the defrost vent started for me today. Followed the ideas in this thread and found what appears to be a snapped vacumn line in the engine bay.
https://ibb.co/R0Y57Bv
What is the easiest fix here? Is there a two ended nipple connector that I could just use to reconnect the line?
Anyone know the part number?
Dude-Ford
34
01-10-2023 12:08 PM
oldcoupe42
08-14-2016 07:39 AM
mustange70
07-12-2012 06:46 AM
Bananarama
Modular V10 (6.8l)
17
10-03-2010 10:14 AM
kupaa
10-02-2009 08:04 PM
Quick Reply: AC comes out of defrost vents
