AC comes out of defrost vents - Ford Truck Enthusiasts Forums
Old 08-14-2014, 12:49 AM
snorindad's Avatar
snorindad snorindad is offline
snorindad has a very good reputation on FTE.snorindad has a very good reputation on FTE.snorindad has a very good reputation on FTE.snorindad has a very good reputation on FTE.
So when my ac is on it mostly comes out the dash vents but some comes out of the defrost vents. Like 70-30 I guess. If I am not mistaken it is all controlled by vacuum. Any suggestions?
Old 08-14-2014, 12:57 AM
Rellick's Avatar
Rellick Rellick is offline
Rellick has a good reputation on FTE.Rellick has a good reputation on FTE.
Quote:
You are correct, i would check for vacuum leaks.
The nice thing is, the climate control and hubs are ALL that is vacuum controlled. My F150 had a vacuum leak that made it run like junk, took me months to find.
I hear the hub lines are a common spot for the leaks.
Old 08-14-2014, 09:18 AM
rocco7869 rocco7869 is offline
rocco7869 is starting off with a positive reputation.
The vacuum canister is on the passenger firewall behind the battery. Thats a good place to start.
Chuck
Old 08-14-2014, 09:20 AM
bthr22's Avatar
bthr22 bthr22 is offline
bthr22 has a good reputation on FTE.bthr22 has a good reputation on FTE.
You could try this little adjustment on the vacuum pump. I have yet to try it on mine. If that doesn't work, the pumps are relatively inexpensive to replace.
This is assuming you don't have a vacuum leak anywhere else.
Old 08-14-2014, 09:22 AM
TxMav's Avatar
TxMav TxMav is offline
TxMav is gaining momentum as a positive member of FTE.
Also, the little valve on the passenger side near the firewall behind the oil fill cap. It's black and a little bigger than a golf ball. The hose fell off of it on my truck and caused the same symptom. Easy fix. Just find the hose and reconnect it to the valve.
Search for this thread, it is helpful too. 'AC blows out Defrost'
This thread: http://www.ford-trucks.com/forums/13...=blows+Defrost
Old 08-15-2014, 05:36 PM
snorindad's Avatar
Thanks for the reply's I will try and check this all out over the weekend.
Old 08-16-2014, 08:29 PM
miked_939 miked_939 is offline
miked_939 is starting off with a positive reputation.
Quote:
Originally Posted by bthr22 View Post
http://youtu.be/6F96gOhTBEI
^definitely check the vacuum pump, there was a tsb for it being inoperative or running continuously. I had to replace mine
Old 08-17-2014, 12:49 AM
Yahiko's Avatar
Yahiko Yahiko is offline
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
I have some diagrams if it will help.
AC 1
AC 2 Valve
AC 3 EATC
What I don't have is the 4X4 diagram. I'll try and get that up for you later.
Sean
EDIT : Got the Service info from the workbook for you. One nice PDF for you.
Old 08-17-2014, 08:00 AM
bigredtruckmi's Avatar
bigredtruckmi bigredtruckmi is online now
bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.
Would this diagram work for a 04?
Old 08-17-2014, 08:20 AM
Yahiko's Avatar
Some things will be the same. But not all.
I no longer have a 2003~2004 to look at.
Sean
No air blowing from floor vents IIGood Explorer, Sport Trac, Mountaineer & Aviator 6 01-21-2016 07:12 PM
Vents racin 1997 - 2003 F150 4 01-14-2016 10:00 PM
Air only comes out defrost vents on 2001 E150 mappy881 Cooling, Heating, Ventilation & A/C 5 01-04-2016 07:37 AM
AC/Vents opening/closing on their own F350GK 1987 - 1996 F150 & Larger F-Series Trucks 14 10-13-2015 05:34 PM
1991 F250 - AC/Heat/Defrost Selector Issue WoodBoss 1987 - 1996 F150 & Larger F-Series Trucks 4 03-09-2015 08:53 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
