351-400 harmonic balancer
My 400 is totally whipped. I picked up a rebuilt 351m shortblock. I have a 1yr old balancer on the 400. According to Oreilly's website my 400 balancer is listed for a 351m if it is stick shift. With an automatic it lists another balancer. Would I be able to really use this balancer without causing problems because I have an automatic?
You know that's an interesting question. I've seen the same part number for all 351m and 400 engines but that can't be right. The cranks are different and of course a flywheel vs a flex plate it would seem would make a difference.
Anyone have original part numbers for the various applications?
Thanks for the input. It seemed weird when I looked at that on their website. I'm gonna use it. Now I'm going to move on and decide if I want to change the cam before I put it together. It has a new original grind cam in it, plus the stock timing chain. I have the stand up chain that was in the wasted motor, it only has around a 1,000 miles on it. So I may get a summit 5200 cam and use the stand up chain. I'm just wondering if I should update the valve springs so I don't have a bind issue. Is that exhaust side to much lift for the stock springs?
The roller tip should be just shy of the valve tip center to start and then move over center and back with lift/release. Push rod length will determine that.
Interesting on the balancer parts numbers. thanks for the info.
There must be some difference however or there wouldn't be two part numbers.
hail destroyer
01-24-2019 10:07 PM
dutchlincoln79
02-28-2008 04:40 PM
Cowboy_351
02-21-2007 03:22 AM
Strokin' Ace
37
02-21-2005 05:57 PM
