Progress on 46 1/2 Ton
#61
#63
#64
Deb, it was great meeting you last night. Your truck is looking great. You'll be driveing it in no time. I will make the blocks this weekend. I am going to make two test pieces out of white oak. One 3/4" and one 1" thick you can bolt them up and see if you like the gap under the fender
#65
I may be wrong here and I'm sitting on my couch not near my truck, but The start button is actually a ground which completes the circuit through the dash. That is why there is only one wire to it. Because of this I don't think there is actually 'power' to it. Electrical is my worst aspect of truck fixing so I could be off base here...... Nice job on the start btw.
#68
That's a nice looking truck. Mounting them on the side was another option I was considering, but the other style mounting brackets would need to be used and would require drilling holes in the box or stake pockets. I like where we have them positioned now (less chance of messing something up).
#69
#70
#71
I do like them there; you did a great job! I'm pretty sure mine will never be relocated there, unless my body shop guy does the drilling.
#73
#74
#75
Nice truck
I like the way you have done your truck. I was curious about the engine. Did you modernize the distributor or is this a newer engine? My 46 has the crab distributor in front of the motor. I have kept mine stock also but did switch to the electronic ignition. I just tore it down for a new clutch pressure plate and throw out bearing and fly wheel grind. It had a terrible chatter on take off. It now is smooth as silk when I let the clutch out. I have it in Florida where I think it might stay for a few years. I had so much more fun with it down here.
Did you paint your truck yourself or have a painter do it? It is very sharp and so smooth looking. I had mine painted but hope to do my next one myself with a lot of practice. Good luck, Steve
