Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
  #1 (permalink)
Old 08-13-2014, 01:07 PM
'50'sFever '50'sFever is offline
'50'sFever is starting off with a positive reputation.
'79 C-4 trans w/LOW lockout clip on valve spool??
I hope the referees allow this- I have this also posted over in Clutch/Trans/Diff.. forum, so if you want to respond, please go there to do so....
Have this trans in '56 F100. Tag says it out of '79 Fairmount. Column shifter won't go into LOW position. Only 'DR' and it works/shifts/downshifts as it should- thru all 3 gears. Just couldn't move shifter all the way into LOW.
Trans tag hand stamped: XD9ZP-EEET-20 on one side. The other side is regular factory stamped: PEE ET1 M18B (first line), D9BP KA (second line).
It has flexplate & torq. conv. mods like those on '79 Mustang Indy Pace car prepared by Jack Roush.
Anyway, I pulled this trans valve body & this is what it looked like:
Click the image to open in full size.
I searched internet & found only valve spool images that have only the 'C' clip on the leftside/end of the spool. This keeps it from falling out during disassembly. None had a second 'C' clip (right side), as my trans has. This is keeping it from the LOW only position.
What's going on here- Why would it be there? Would it be ok to just remove it so this can be a 'normal' trans re shifter positions?
Thanks for any inout/help here...john
(again, any responses, please, in Clutch/Trans/Diff... forum)
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
C-4 with LOW lockout clip on spool valve?? '50'sFever Clutch, Transmission, Differential, Axle & Transfer Case 4 08-13-2014 11:41 PM
6637 S&B Intake 1st impressions HKusp 1999 - 2003 7.3L Power Stroke Diesel 17 04-08-2014 08:59 AM
Replacing slave in M5OD trans F-erOnlyRunsDwnhill 1987 - 1996 F150 & Larger F-Series Trucks 2 03-30-2014 05:16 PM
Automatic E40D Swap to 5 Speed (Mazda M5R2) Ztitan 1987 - 1996 F150 & Larger F-Series Trucks 51 03-19-2014 09:57 PM
2000 XLT 4X4 A/C 903ASP Cooling, Heating, Ventilation & A/C 2 07-14-2013 08:39 PM
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
vbulletin Admin Backup
