Hydro boost brakes - Ford Truck Enthusiasts Forums
Hydro boost brakes
Old 08-13-2014, 12:10 PM
4drf350 4drf350 is offline
4drf350 is starting off with a positive reputation.
Hydro boost brakes
Hi Everyone I have a 1967 bronco an I put hydro boost an disc brakes on it an a ford power steering pump . So when I turn off my motor almost all the fluid comes up an out of the power steering pump . Does any one know why that is .
Old 08-14-2014, 06:07 PM
DW SD DW SD is offline
DW SD has a very good reputation on FTE.DW SD has a very good reputation on FTE.DW SD has a very good reputation on FTE.DW SD has a very good reputation on FTE.
sounds like the accumulator is pushing fluid back out.
Is it a new hydroboost?
Does it work properly when the engine is running?
Doug
Old 08-14-2014, 06:25 PM
Yea it works good . I even changed the hydro unit an it does the same thing . Not sure how to fix it . I am thinking it might be the ps .
Old 08-14-2014, 06:32 PM
1. I wonder if the pump should have a check valve that might be missing?
2. Or perhaps the pedal doesn't return 100% to close the inlet valve from the PS pump. In my setup, I have a threaded pushrod. Are you sure the pushrod is adjusted properly?
If I listen closely, I can hear fluid flowing once the pushrod comes off of the closed position.
Old 08-14-2014, 06:37 PM
I am thinking I might put on a power brake from an newer bronco .
Old 08-14-2014, 06:45 PM
I'd try a newer pump first.
The hydroboost offers great stopping power and firm pedal. I up-sized my master cylinder by one size and love the feel (very short throw).
Doug
Old 10-12-2014, 06:11 PM
Infinite Monkeys Infinite Monkeys is offline
Infinite Monkeys is starting off with a positive reputation.
I'm pretty sure it needs to be bled out. If there's air traped in the system it will pour out like you have mentioned. I tried every way to bleed mine and finally had to vacuum bleed for it to get all the air out.
Old 10-12-2014, 10:56 PM
Mine practically self bled. Actually it did and nearly instantly. My unit is below the floor boards though. I wonder if you can crack the lines and bleed that way with the engine running?
Doug
Old 10-13-2014, 08:11 AM
Seems some conversions go easier than others. Mine was a nightmare. What ended up working for me was pulling a vacuum on the PS pump reservoir, disconnect the pitman arm and turned the steering wheel about a million times. (engine off)
Did that a few times till it finally worked.
I don't think every one should have the same problems, easiest way is to disconnect the pitman arm, with the engine running, turn the wheel back and forth, lock to lock till your arms fall off. MAKE SURE the pump does not go dry.
Once fluid level has stabilized and no more bubbles can be seen, you're good to go. You might have to let it sit overnight and redo the next day.
There's a lot of hose and several components to bleed out.
Hydro Boost Hose Routing robert kelsey 1999 to 2016 Super Duty 5 03-10-2016 11:28 AM
hydro boost mod obs dieselman86 1994.5 - 1997 7.3L Power Stroke Diesel 5 10-18-2014 10:35 PM
Power steering pump MOOSE_MACHINE 1994.5 - 1997 7.3L Power Stroke Diesel 11 07-26-2014 08:14 PM
7.3 Hydro boost pressure line sand_fiend 1999 - 2003 7.3L Power Stroke Diesel 7 03-22-2014 06:49 PM
Hydro Boost Big Sky 1999 - 2003 7.3L Power Stroke Diesel 3 07-07-2013 04:41 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
