'55 f100 window regulator
Old 09-09-2013, 06:38 PM
Daddyo's garage's Avatar
Daddyo's garage
Daddyo's garage is offline
Hey guys! Anyone know if I you can rebuild a driver's side window regulator, or do I need to get a new one?
Old 09-09-2013, 07:19 PM
raytasch's Avatar
raytasch
raytasch is offline
Believe Nothing
Try these folks for parts. I've replaced a couple crank studs. Boils down to how much time you spend repairing vs replacing. A long time ago an old boy told me that "If it is steel, it can be repaired."
http://www.midfifty.com/search.php?s...ndow+regulator
Old 09-09-2013, 08:03 PM
teardropty's Avatar
teardropty
teardropty is offline
I rebuilt one in a 54. Honestly, the best solution is to be a GOOD used one (easier said than done but possible), second a new Chinese knockoff (quality sometimes questionable) and third rebuild what you have. The studs aren't bad to do but if the gear teeth is stripped, riveted loose, etc. it takes time and often isn't worth it. Good luck.
Old 09-09-2013, 10:50 PM
1oldtimer's Avatar
1oldtimer
1oldtimer is offline
I rebuilt one of mine and several on other old cars. My .02 is....
#1 Good used
#2 Rebuild yours with good used pieces
#3 Nos if you can find it, but $$$
A repo if you must, but just to hold you over until you decide on #1-3.
Old 09-10-2013, 06:19 AM
james G. phillips's Avatar
james G. phillips
james G. phillips is offline
Go to ebay motors website. Type in 53 F100. Go to page 2. A guy has two .He has taken out both regulators to install power windows and starting bid at $40.00. They would be well worth it for that price.
Old 11-01-2013, 09:25 AM
Daddyo's garage
Can you use parts from the passenger side to fix the drivers side?
Old 11-01-2013, 09:26 AM
Daddyo's garage
Can parts from the passengers side be used to repair the drivers side?
Old 08-11-2014, 11:12 PM
Daddyo's garage
Well....... I found a deal on a repop for $40 so I went for it. Today it stopped working. Acts like stripped gears. Should a known! Figured I'd get by till I could replace or rebuild the old one. Oh well..... I don't think it lasted a month. 😕
Old 08-14-2014, 11:33 AM
gerrymoe's Avatar
gerrymoe
gerrymoe is offline
I have one that looks to be in good shape, splines on handle crank shaft look good, all teeth are there on regulator, probably needs new roller mechanisms. You can have if you can come get it or arrange shipping or send me the shipping costs I'll box it and send it to ya. Another way is I'll be in Morro Bay CA for the North South run, if you are coming or know anybody in the pick-up Limited F-100 club who is going I would be glad to give to them just need info
Gerry
gatorjaws
11-14-2018 11:23 PM
nova801428
05-17-2017 05:01 AM
rews2
03-10-2016 03:27 PM
cookieman69
04-22-2011 07:17 AM
medicpg
09-29-2003 09:29 AM
Quick Reply: '55 f100 window regulator
