Injector cups - Ford Truck Enthusiasts Forums
Injector cups
Old 08-13-2014, 01:10 AM
Kulapp Kulapp is offline
Kulapp is starting off with a positive reputation.
Injector cups
Ordered new cups from Riff Raff with the tool to pull them. Just wondering any of you guys have tips for me before I dig in.
Old 08-13-2014, 01:11 AM
Yikes pics are big.
Old 08-13-2014, 01:18 AM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Moved to the 7.3L PSD forum.
Stewart
Old 08-13-2014, 06:12 AM
Tugly's Avatar
Tugly Tugly is offline
I'm a cautionary tale.
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
Click the injector cup link in my signature... and program your therapist on speed dial.
Old 08-13-2014, 11:43 AM
Riffraff Performance's Avatar
Riffraff Performance Riffraff Performance is online now
PREMIUM SPONSOR
Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.
Old 08-13-2014, 09:43 PM
Sader's Avatar
Sader Sader is offline
Sader has a good reputation on FTE.Sader has a good reputation on FTE.
Follow the instructions from Riff Raff. I did and the job is not too bad. Set apart some time and don't go too fast. It's not too bad of a job.
Good Luck!
Old 08-13-2014, 11:54 PM
BWST's Avatar
BWST BWST is offline
BWST has a good reputation on FTE.BWST has a good reputation on FTE.BWST has a good reputation on FTE.
It was a hell of the job for me. Clean the bores well. I could not get the cups to seal until the seventh time under the valve covers. Turned out I did not clean them enough for the loctite to seal. Therapy is helpful for PMS in general, and this job in particular...
Old 08-14-2014, 01:17 AM
Went good today had a bit of time to wrench on it not bad at all. Have one ? How did you guys get the valve cover bolt off next to pass side ac. Swivel set up? Might need to stop buy Sear or the Snap on truck.
Thanks
This site is great
Old 08-14-2014, 07:21 AM
Pikachu's Avatar
Pikachu Pikachu is online now
Pikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud of
Old 08-14-2014, 07:29 AM
Tugly's Avatar
You need a 13 mm flex socket, a universal makes the assembly too big. If it's a truck, you can get at the bottom bolts through the wheel well. If it's an Excursion, you have to wait until the stores open.
You will want a host of items to make the job easier, every tool I used is posted in that link in my signature (complete with pictures and videos). The Mity-Vac with a vacuum gauge is indispensable on the 7.3L.
AC and Power steering/Alt. brakets z31freakify Ford Truck Parts for Sale 0 08-09-2016 10:00 AM
82' F100 82fordowner 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 07-14-2016 10:56 AM
5.4 Factory Intake Manifold 04mudslinger Ford Truck Parts for Sale 0 04-08-2016 08:21 AM
Springfield, Mo Swap Meet bjmayberry2 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 08-10-2015 07:26 PM
Mustang II front end on 56 F100 spring problem help Bader BuQais 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 02-19-2015 11:16 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
